Valve Cover
- otakar
14 Feb 2009 16:52 - 14 Feb 2009 17:00 #265075
by otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
Replied by otakar on topic Valve Cover
Actually guys, I do use RTV. There is a trick to it and there is a reason for it. If anyone has noticed, when you try to remove an old gasket which has been put on dry, "IT IS A B**CH" That is because the bonders in the gasket material bond themselves to that beautifully clean Aluminum. The way to use RTV, is to first of all use the right one. I personally use the Permatex Hi Temp "Ultra Black". Second of all, what you have to do is, first put it on one side as evenly and thinly as you can and let it totally cure. Flip the gasket over and do the same thing on that side. After it has cured install the gasket. What you will find is that, It will not stick so you can remove it nicely, and it will seal extremely well. I have been working on these since 1978 and have never had a problem.
Otto
Otto
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 14 Feb 2009 17:00 by otakar.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
14 Feb 2009 17:18 - 14 Feb 2009 17:22 #265078
by kzz1p
Replied by kzz1p on topic Valve Cover
To each, his own.
The only sealer that I will use, is plain old, Gasket Cench.(the one with a girl on a swing on the label) That very thin yellow sealer that can be used wet or tackie. I seal all the cover gaskets (valve cover, clutch, dyno, point housing,etc.) More or less I glue the gasket to the cover. If I have any problems, the gasket comes off with the part. It is easy to take the part to the workbench and clean it. Some gaskets will still be useable. The real trick is to do things right, so you don't have to take it apart. I hate oil leaks, they drive me crazy. I will not use silicone of any type. I don't want that crap showing or dripping on my paint or cases. Racers use it when they need a quick fix. There is nothing worse then a nice looking motor with silicone hanging out of it.Once again, different people have different ideas.
PS - I have made gaskets out of soap boxes and even a sheet of paper. anything will work, if you have clean dry surfaces.
Last edit: 14 Feb 2009 17:22 by kzz1p.
- gane
- Thank you received: 1
14 Feb 2009 18:51 #265089
by gane
[img][/img] 1977 KZ1000A1
Replied by gane on topic Valve Cover
Somtimes you win sometimes you lose, I like to paint the top side of V/C gasket w/ copper coat. it's a light coat and won't migrate to oil control orifices. it locates gasket, and in the event it breaks next time in, the majority of gasket will be w. cover where cleaning is on the bench instead of attop head. Tip, if your rings are on their last legs, cam end plugs can be installed inside out. not pretty, but they won't blow out. G
- racer54
- Thank you received: 114
14 Feb 2009 19:22 #265096
by racer54
Replied by racer54 on topic Valve Cover
I put the valve cover on dry also. Although what Otakar does sounds like an idea to try. I use permatex on the end plugs. Put a thin film on the curved part and then press it into place. Wipe off any excess. Then a very then layer across top. I am anal about leaks on my motors so I like to seal them up good.
- l0g1c
- Hanging on for dear life.
14 Feb 2009 20:16 #265108
by l0g1c
'81 KZ750 LTD
'72 CB350K
Omaha, NE
Replied by l0g1c on topic Valve Cover
For the scraping, I'd just have a buddy hold a shopvac up there while you scrape away. This, along with the towels, should do the trick, as long as you don't suck up any shop towels. :laugh:
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- grumpy56
- Thank you received: 6
15 Feb 2009 05:36 #265133
by grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
Replied by grumpy56 on topic Valve Cover
Lots of great discussion and ideas. Thank you all!
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
15 Feb 2009 08:17 #265150
by CoreyClough
'85 GPz550(ZX550-A2)
Replied by CoreyClough on topic Valve Cover
I'm a dry guy as well, with some sealer on the cam end plugs and their bolt threads. Of course I wipe any excess, if any, off after the squish-factor. I've seen the orange stuff on engines, and it makes my teeth ache. The Right Stuff has worked great for all I've applied it to.
All you're really looking for is for the gasket or sealer, to cover up any imperfections in the two surfaces, keeping the oil in, and the outside conditions out.
If APE made cam end plugs for the GPz550(ZX550), I'd buy them for all my GPz550 needs.
