- Thank you received: 6
Valve Cover
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
1972 Suzuki GT380 (In-Process)
In The Past...71 TM400, 72 H-D SS350, 72 GT380, 75 Z1B, 77 XLH, 79 CB750K
- bountyhunter
- Thank you received: 337
Be careful scraping the sealer crap off. I pack rolled up paper towel pieces along the edges to keep the junk from falling down when I do it.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- franknsr
I told him no thanks, this is how grandpa showed me how to do it and my stuff doesn’t leak. Another guy at the counter said yup, that’s how he does it too.
I’d like to hear from you guys on whether you use anything on the gaskets or not.
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
- RonKZ650
- Thank you received: 240
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- saxjonz
- KawboyZ
- Thank you received: 76
While you got that cover off it would be a nice time to start polishing it. I would say. But I guess I am a kz geek.
79 LTD B3
- l0g1c
- Hanging on for dear life.
- Thank you received: 1
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- bountyhunter
If they are old, they will probably leak unless you run a thin line of gasket sealer across the tops of the plugs and onto the edge of the head next to it. I use the HI-Temp black stuff, works very well.Thank you guys. I will just scrape off the old stuff and apply the gasket dry. Do any of you use a little sealant on the rubber cam plugs?
FYI, are you reusing the old gasket? If so, I would seal it. If it's new and the two surfaces are clean and smooth, it should seal along the aluminum areas. The stupid rubber plugs like to leak, especially at the corners next to the aluminum.
- grumpy56
Lewis
1982 KZ1000-J2
2006 HD FXD35
1970 Suzuki T350
- RonKZ650
