- Thank you received: 1
Valve seals revisited
- H2RICK
- Is this a fun bike, or what!!!
12 Feb 2009 19:50 #264411
by H2RICK
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Valve seals revisited
Damn....now THAT'S a slick tool....even if you had to work around the frame rails somehow.
Hmmm....this needs more thinking....I was going to make a tool that bolted onto the head using the valve cover bolt holes. Need more thinking and designing here....:blink: :silly: :side: :S :ohmy:
- timebomb33
- Thank you received: 10
12 Feb 2009 19:53 #264417
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Valve seals revisited
it easer to just pull the head and that way nothing can fall down inside the engine.
- shighley
13 Feb 2009 06:07 #264609
by shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
Replied by shighley on topic Valve seals revisited
Hi All; A word of caution when using this style tool. Be sure the knurled portion has clearance in the lifter bore. I once had major damage to my Z1A head when a friend showed me how his new "trick" tool worked. I had to change my underwear afterward. Have you ever heard the term broaching? It totally hosed up the bore. Be aware. Ride safe, Steve
- franknsr
14 Feb 2009 14:26 #265047
by franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
Replied by franknsr on topic Valve seals revisited
Timebomb and H2 you are right, the tool works great on the outside cylinders but won’t fit right on the insides.
Meet my new tool. Piece of pipe with a section cut out and a long prybar. Got the valve seal swap down to 10 minutes each with this baby.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- HerrDeacon
14 Feb 2009 15:59 #265061
by HerrDeacon
Replied by HerrDeacon on topic Valve seals revisited
Amazing CSRchopper, good stuff. Very ingenious.
