Valve seals revisited
- franknsr
11 Feb 2009 20:05 #263939
by franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
Valve seals revisited was created by franknsr
A while back I asked about replacing the valve seals on my bike without removing the head. I wanted to let you guys know that not only is it possible, but it went surprisingly easy. Well, most of it.
I fed a length or soft cloth rope into the cylinder while it was down, rotated it up, pushed down on the spring and used a magnet to remove the keepers in less time than it took you to read this. Old seal out, new seal in, then reassembly.
OK, first one took about 45 minutes to compress the spring and get both keepers in. Next one about 30 minutes. Hmmmm. I checked on line and found a cool valve keeper install tool. There is even a video on you tube;
So I did all this to save $45 on a head gasket, but to tool that makes this easy is $32. Go figure.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- PLUMMEN
- Thank you received: 104
12 Feb 2009 00:19 #264056
by PLUMMEN
Replied by PLUMMEN on topic Valve seals revisited
im impressed !
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
12 Feb 2009 00:46 #264060
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Replied by oldkaws4ever on topic Valve seals revisited
I second that......very nice CSRchopper, very nice indeed.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- BSKZ650
- Thank you received: 14
12 Feb 2009 05:26 #264087
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Valve seals revisited
way cool,,,
- Thank you received: 797
12 Feb 2009 06:38 #264104
by 531blackbanshee
Replied by 531blackbanshee on topic Valve seals revisited
so is the tool you showed us the one that removes and replaces the valve keepers?
if so does it work as well as they advertise?
a friend here at work had shown me the video but i only work on things people bring me so they are already off and i use my conventional valve spring tools.
but when i needed to remove and replace the seals on my z1r i could have saved a lot of time with this tool.
thanks for posting.
thanks for posting.
- mark1122
- Keep twisting it
- Thank you received: 109
12 Feb 2009 07:21 - 12 Feb 2009 07:22 #264119
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Valve seals revisited
VERY COOL.
how does that tool work?
So how did u compress the springs??
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 12 Feb 2009 07:22 by mark1122.
- franknsr
12 Feb 2009 18:44 - 12 Feb 2009 18:45 #264323
by franknsr
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Replied by franknsr on topic Valve seals revisited
You compress the springs by pushing on them, or if they are too strong for that, then you....hang on now....use a hammer on the tool.
The trick here is if you want to do this without removing the head, then you have to get something under the valve to hold it in place so it doesn't drop into the cylinder. I used rope but others have used air pressure.
I feel like Hannibal from the A team; "I love it when a plan comes together."
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Last edit: 12 Feb 2009 18:45 by franknsr.
- timebomb33
12 Feb 2009 19:15 #264347
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Valve seals revisited
that works great on the out side cylinders but what about the middle pair. not much room under the back bone of the frame.
- franknsr
12 Feb 2009 19:25 #264363
by franknsr
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
Man I hate it when logic ruins a otherwise perfectly good plan.
You're probably right.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- timebomb33
12 Feb 2009 19:32 #264382
by timebomb33
sorry there is no easy way to do things right
- jmods62
12 Feb 2009 19:33 #264384
by jmods62
Replied by jmods62 on topic Valve seals revisited
hey dude, tell me where to buy a cylinder head gasket for 45 bucks...i need one...joe
- timebomb33
12 Feb 2009 19:38 #264397
by timebomb33
cometic gaskets or z1-enterprises, or ape what do you need copper or fiber type.
