- Thank you received: 1
Clutch Cable
- poolboy
I have a 1980 KZ-750 4.
While waiting for Carbs from WG.
I decided to replace Throttle Cable and Clutch Cable.
The Haynes manual that came with the bike shows very little to nothing about Cables, and I know I need a factory Manual, its on the list.
Throttle Cable was easy enough.
The Clutch Cable, the upper part that goes into the hand control is easy enough, the bottom part that hooks underneath the bike is hard to see.
Maybe someone could say a few words on hooking up the bottom half of the Cable, or maybe a picture showing that area. Just don''t want to flub something up.
1980 KZ750H ,WG's carb rebuild, V&H 4-1 Exh ,WG wiremod, Dyna 3.0 ohm coils, Dyna-S EI DS2-2,New Bridgestones, O-ring Chain,
- MFolks
- Thank you received: 540
After the cable is re-installed, the clutch will need adjustment to work properly. There should be a slack adjuster mid way down the lenght of the cable. I like to collapse the cable as short as possible and then adjust the operation of the mechanism allowing smooth clutch operation.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- Thank you received: 2829
- H2RICK
- Is this a fun bike, or what!!!
You'll be AMAZED:woohoo: at how light the clutch pull becomes after this "tuneup".
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- Sandy
- Fly High,Tony
- Thank you received: 13
++ All the above PLUS.....I'd disassemble the release mechanism, thoroughly clean it in solvent, check for beat up balls/ramps etc, grease the heck outta everything and then reassemble it. I'd also lube the new cable while you can.
Plus one!
BIG difference,if it hasn't been done in a while.:woohoo:
1977 KZ1000 A-1
- poolboy
Hands down this forum is the greatest.
650ed I'll check out EBay, Thanks:cheer:
- poolboy
Anyway its really dirty. I'll bet it has'nt been cleaned in years. I have bid on a factory manual at ebay. By the time I get everything cleaned the manual will be here and I can adjust the clutch by the factory manual.
Kinda hard for a guy thats 69 years young to get down that low to the ground but I did it. Thanks again Sandy, H2RICK, 650ed, trianglelaguna, & MFolks.............:woohoo:
- l0g1c
- Hanging on for dear life.
People will recommend lots of stuff from motor oil to silicone lube. Use what you like as long as it is NOT a penetrant like WD-40. Personally, I like the silicone lube.
I happen to have my cover off right now. I'll snap a couple photos when I get home.
'81 KZ750 LTD
'72 CB350K
Omaha, NE
- gane
[img][/img] 1977 KZ1000A1
- Thank you received: 2098
