- Thank you received: 5
Deck Height
- dshelly
I was asked about cam timing, which was dead on. Also was asked about the deck height. Which I did not know the answer to at the time.
Now I have the engine on the stand tore down and can say that the deck height measures .015 across all cylinders.
So My question is. Is this good or bad? Oh,by the way ,my pistons are stock 70mm wiseco 10.25:1 if that matters.
Occupation:Machinist 25+ exp.
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- KruZer
If this is right then you can install a thinner base gasket (up to .015 thinner) or have your head milled .015 to bring your pistons to .000 (zero) deck height. You can run the pistons out of the hole by a few thousands but don't do it unless you've checked all of your valve to pistons clearances and piston to top of combustion chamber clearances.
Milling your head or installing a thinner base gasket will increase your cranking pressure and compression and fixing the valve in #3 will help overall engine performance.
Good luck,
Buzz
*1977 1000, 1975 KZ998 LSR bike.
- nads.com
- Thank you received: 20
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
We had a thread a few weeks ago titled "piston to head clearance" serval people gave their ideas of the pros & cons. If you can't find that thread, click on my screen name and it is page 9? of my posts. Maybe it will be helpful. It's just a suggestion.
- 77KZ650
- Thank you received: 7
07 MDP Rookie of the Year
- BSKZ650
- Thank you received: 14
The main thing to check, is the deck flat and is the head flat, if not then get them milled.
Since you said you have a valve leaking, a valve job for the entire head should be done along with a bench shim.
77 ltd1000, current rider
76 kz900, just waiting
- dshelly
'77 Kz1000B1
'78 Kz1000A2
'76 Kz900LTD
- KruZer
Of course you're right. What I meant to say was either reduce the thickness of the base gasket or mill the cylinder block.
I would still replace the cylinder base gasket (either with a like or thinner gasket) since the head is already off the bike and the seal between the base gasket and the engine block is probably already jeapordized.
Good luck,
Buzz
- mark1122
- Keep twisting it
- Thank you received: 109
I Think I'll just leave the deck height alone. No need for any extra machine work. Sounds like a valve job should fix the problem. I just want a good streetable engine. Thanks for the input everyone.
I agree with u here. no need to get fancy .
the only reason u would mill the cyl or head would be to true them or increase compresion or (Cyl only) to improve squish clearance. lower squish clearance improves the burn in the cyl, allowing for more compresion.
If u start to play with this stuf u need a good knowledge of the pros and CONS. u can do serious damage if u make a mistake.
how did u measure the .015" ? did u have the base gasket installed? did u torque the cyl's down using a spacer?
Do u have a history with this bike? is the cly and head stock or have they ever been milled?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
