- Thank you received: 5
Crankshaft Restoration
- SPARKY47
- 1980 KZ500 B2
09 Feb 2009 03:59 - 09 Feb 2009 04:00 #263212
by SPARKY47
1980 KZ500 B2
Crankshaft Restoration was created by SPARKY47
Has anyone ever done this to a crank? I wonder.
My crankshaft has a service limit of 31.96mm on the journals and measures 31.92mm.
I just got off the phone from a place that does "metal spraying" using a variety of materials.
They would grind the journals down by 50 thou and then spray this material which has a Rockwell Hardness of 35 on and then grind to size. They tell me that they've done this with cranks from TVR's.[excellent British cars]
Does this sound a realistic way to go or is there something here I don't know?[older I get, less I know:woohoo: ]
Cost : in the region of £300 [$450] for 5 journals.:blink:
All comments appreciated. [even yours omr!]:lol:
1980 KZ500 B2
Last edit: 09 Feb 2009 04:00 by SPARKY47.
- PLUMMEN
- Thank you received: 104
09 Feb 2009 04:04 #263213
by PLUMMEN
Replied by PLUMMEN on topic Crankshaft Restoration
cant find a good used crank?time to stuff kz650 motor in there !:laugh:
- SPARKY47
- 1980 KZ500 B2
09 Feb 2009 04:09 #263215
by SPARKY47
1980 KZ500 B2
Replied by SPARKY47 on topic Crankshaft Restoration
I've measured 5 so far, all ****ed.
Trouble is these bikes are all old now,ol ma kawa maketh no more and...AND... I've got new oem pistons to go in, valves, guides....so I'd rather stick to 500.
Problems,problems eh?
1980 KZ500 B2
- SPARKY47
- 1980 KZ500 B2
09 Feb 2009 04:47 #263217
by SPARKY47
1980 KZ500 B2
1980 KZ500 B2
- BSKZ650
- Thank you received: 14
09 Feb 2009 05:14 #263221
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Crankshaft Restoration
I have seen the spray metal done on industrial cranks before, they dont turn near the rpm as the bike does, so I am not sure how it would hold up.
they used to chrome the cranks for some racing applications, kind of the same process and I know they worked, tht might be another avenue to look at
- SPARKY47
- 1980 KZ500 B2
09 Feb 2009 05:41 #263225
by SPARKY47
1980 KZ500 B2
BSK650,thankyou.
Plating sounds interesting, I'll have a look around and see what comes up.
1980 KZ500 B2
- APE Jay
- Banned
- Thank you received: 58
09 Feb 2009 13:14 #263309
by APE Jay
Replied by APE Jay on topic Crankshaft Restoration
I have a feeling you may be getting an incorrect measurement. We service a lot of plain bearing cranks (
www.racecranks.com/
) and have never seen any with all the journals that far below the limit without showing signs of bearing failure.
The 650s would kill the cranks in turbos, etc. but I mean KILLED. You wouldn't even need to measure it.:laugh:
In any event, stay away from that spray stuff. If it was infact worn that bad, you could get a good used crank for way less money and it would be many times more reliable.
Jay
Jay
- SPARKY47
- 1980 KZ500 B2
09 Feb 2009 13:55 #263328
by SPARKY47
1980 KZ500 B2
Thanks a bunch Jay, thats the kind of info that makes this place soooo good.
Funny you should mention inaccurate measuring, the tool I'm using specifies an accuracy of plus/minus 1 thou, and I'm half blind [no joke] so I'm going to plastigauge with the new shells and get my associate in crime to confirm the reading. I'll put some piccys up for the [ladies of the night]
Can't thank you enough for that. Best Wishes.
1980 KZ500 B2
- 77KZ650
- Thank you received: 7
09 Feb 2009 16:23 #263358
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic Crankshaft Restoration
get a good micrometer...
if its actually worn out send it to Marine Crankshaft. www.marinecrankshaftinc.com/
