stuck clutch plate
- OldHippie
I took everything back off, including comp clutch assembly and began from new. Same thing happened, no go in 1st or any gear.
Is this a stuck clutch plate? If so, how do i fix this problem? Any help would be appreciated greatly.
There is power in words...just don't put too many together.
my ride: KZ1000P19
- KruZer
*1977 1000, 1975 KZ998 LSR bike.
- Z1109R Fin
- Thank you received: 1
Z1000R ´83...Slightly modified...
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- OldHippie
my ride: KZ1000P19
- RonKZ650
- Thank you received: 240
- jimmybon
74 Z1A900 original
74 Z1A900 stone replica
74Z1A900 barn find
77 Z650B1 Hybrid
81 z650 PIG camp bike
06 ZRX1200R cafe racer project
S1000xr
- Thank you received: 2098
Hi. I have a kz1000 P-19. I had put on a new clutch cable, but had adjusted the set screw too far, and "over ramped"(?) the comp clutch. I put everything back the way I started, without over adjusting anything this time. i started the bike and it wanted to lurch forward and when I dropped it into to first, it sifted hard, I released the clutch but no go.
"Comp" meaning "competition" or "complete" or something else, or does it matter? :huh:
Am thinking it's not unusual for a KZ after cold starting to lurch forward upon initial shifting from neutral into first gear.
When squeezing the handlebar clutch lever, the normal resistance should be observed as usually attributed to disengaging the clutch (spreading the plates against the springs). In this case, is the lever easily greeting the handlebar like nothing's going on down there?
Just guessing at this point, but sounds as if the lurch forward is normal, and the screw still mal-adjusted without the necessary gap between it and the clutch push rod. Lack of necessary gap doesn't prevent the expected initial lurch. In other words, after the initial cold start lurch, the clutch cannot engage due to the mal-adjusted screw.
When the engine isn't running, it usually won't shift out of neutral unless the rear wheel is rotated as if rolling forward (typical situation with bike on centerstand).
With engine running, it should shift through all gears with clutch fully engaged and without squeezing the handlebar lever (or without any clutch cable whatever).
Good Luck!
- mark1122
- Keep twisting it
Sorry i see there is no ball in the J motor just the kz,z1.According to the diagrams I have looked at for my ride(kz1000 P-19) the push rod has a washer and nut at the end, if a ball-bearing is needed then what size should it be?
Chech that #13102 lever is installed correctly.
If u drain the oil u could remove the clutch cover on the right side.then u could see if the clutch is moving in and out as u pull the lever in and out.U may need a new gasket though.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Z1109R Fin
You may be looking at the wrong end of release mechanism. The push rod (part # 13116) probably has nothing to do with your problem.
1) If it was stuck plates it would definately go if you kick it on #1 gear. And with a very noticeable noice. So I doubt it´s stuck plates. Beleive me, you´ll notice if the plates are stuck and you kick it in gear...
2) After "over ramping" did you open the sprocket cover?????? This is the only way to ease the pressure on release assy (parts nr 13119, 14020, 13102) Part #14020 icludes 3 ball bearings which are moved up and down the ramps in part #13119. Too much play / too long pull will raise the balls on flat surface and the spring in clutch cable isn´t strong enough to pull them back down. To pull them back ease the 4 bolt holding the sprocket cover and you´ll probably can hear a "clunck" when the assy is pulled back.
People seem to be referring to the "worm-gear" clutch assy which is totally different that J-engines assy. And if the plates are stuck it won´t just "lurch" forward....
