Oil cooler plugs/Torque settings
- chelms27
1977 KZ1000...16k miles 2nd owner all original except tires, dyna-coil, and a vance and hines 4 to 1 exhaust.
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Bullitt03737
- MFolks
- Thank you received: 540
- chelms27
- Kawickrice
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- wiredgeorge
Only an idiot would do this... hehehe Trust me, I know the idiot well. Your bike will also get NO OIL while you do this as you won't hit the bypass circuit if you plug those fittings. Get a stock oil pipe which you will notice has a cross passageway between the two main parts.
- wiredgeorge
If you plug the holes you will lose your sending unit, and that would not be smart in my opinion. At the very least put the factory fitting with the sending unit on, then you would have the idiot light operational in case you lose oil pressure. Just my 2 cents.
The sending unit works great when the oil cooler type fittings are plugged... just no oil gets PAST the sending unit to the main oil galley.
- Kawickrice
I could use an oil cooler, my bike gets rode hard in hot weather for long periods.
oldkawman.com has an article on modifying the stock oilpipe to use for an oil cooler.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Kawickrice
with that being said, the light would come on just before the grenade effect.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- wiredgeorge
