1980 750 cyls on 650 block.Will my 650 head work?
- FloridaSteve
04 Feb 2009 12:29 #262176
by FloridaSteve
1980 750 cyls on 650 block.Will my 650 head work? was created by FloridaSteve
Hi Fairly new here but not to old bikes. I picked up some nice low mileage 1980 kz750 cylinders and pistons that have the correct design for the cam chain adjusters mounts for my 79 650 block.
Pic.
My question is will my 650 cylinder head work correctly with the 750 cylinders if I swap out to 750 cams? I've read that the cam sprockets from the 650 cams can be swapped over to the 750 cams. Is this correct?
Also, how big a carb can I realistically get away with assuming a Vance pipe and K&N pods? Will the 26mm 900 carbs bolt on there?
Any other advice about the swap much appreciated.
Pic.
- 77KZ650
- Thank you received: 7
05 Feb 2009 23:24 #262482
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic 1980 750 cyls on 650 block.Will my 650 head work?
yes it will work. you may need to drill out 2 holes for bolts IIRC 6mm to 8mm?
26 or 28mm carbs. use the correct intake boots for the bigger carbs
- FloridaSteve
06 Feb 2009 06:45 #262513
by FloridaSteve
Replied by FloridaSteve on topic 1980 750 cyls on 650 block.Will my 650 head work?
Awsome! Thanks!
