- Thank you received: 1
What gives??
- Becker
- The Doctor Will Rise Again
The reason I'm asking is because I have a 77 KZ650B motor completely torn down in my living room that I'm rebuilding to go into a 79 KZ650C chassis. I also have the engine from the 79 C model and I wanna know which is best to put in for the most horsepower. Neither have the plates on top of the cam covers with hoses coming out of them and I don't know for sure that the B engine came out of a B or that the C's engine is the original. Is there any way to tell??
Thanks for any input/answers/history you might have about this question.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- Thank you received: 2829
- H2RICK
- Is this a fun bike, or what!!!
The 77 and 78 B1/B2 and C1/C2 all used the same engine with 64HP. The engine serial numbers look like this:
KZ650BEXXXXXX where the X's are the sequential serial numbers starting with 000001....or maybe 0000001.
The 78 B2A used a 60HP engine and the 78 D1A used a 58HP engine.
The D engine serials start with KZ650DE.....
I have NO idea how to tell a B2A engine from a standard B engine.
The 79 B3 and C3 used a 62HP engine. I have no idea what the number sequence starts at. This is where things will get murky for you since the engine number will PROBABLY
still have a B in it....so it'll be hard to tell these engines from the 77/78 engines unless you can find a starting number in the archives somewhere.
The 79 D2 used a 60HP engine and I'd ASSUME that the serial will STILL show a D in it....but that's just an assumption on my part.
The 80 B4 and C4 went back to the 64HP engine. Again, I have no idea what the engine serial numbers started at.
The 80 D3 used a 62HP engine and, again, I'd bet that the engine serial has a D in it somewhere.
The 80 E1 used a 60HP engine. No idea of engine serials.
The 80 F1 used a 64HP engine....PROBABLY from the B model so MIGHT have a B in the engine serial. Again I have no idea of the beginning number. The US version F1 used a 62HP engine for some reason.
Since the compression ratios show the same 9.5:1 value for all years listed above, I can only assume that different power outputs were made by carb jetting and exhaust setups/back pressures. I can't imagine that they'd bother making 3 or 4 different cam grinds just for a variation of 6HP over the various models....but that's just a guess.
Becker, I hope this has helped somewhat and not made things worse for you.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
- KawiConvert
- Thank you received: 4
I am interested about the rest as well. I put carb bodies from a 79kz650 on my bike. Everything bolted up from the original carbs so I don't think I traded down, but interested to see.
1978 KZ650 D1 ~ Carb jetting: 107.5 & 20 & 4th groove with pods and 4-1 Exhaust
- BSKZ650
- Thank you received: 14
Steel may be the best to answer that one
77 ltd1000, current rider
76 kz900, just waiting
- JMKZHI
- Thank you received: 48
The 82/83 CSR models came stock w Mikuni BS32 carbs & have the highest listed horsepower. My 81 CSR has the Mikuni VM24s & has a lower hp. The only significant difference in the bikes of which I'm aware is the carburetors.
- H2RICK
Very interesting on the 1979 B3/C3 HP ratings. One Kawasaki FSM (#99924-1001-03 Sept 2, 1980) says 64HP another Kawasaki FSM (#99924-1007-03 July 25, 1979) says 62HP. I wonder which is correct? Ed
WAG here but maybe the -1007- FSM (which I have) doesn't take into account the smog stuff on the US market engines.
They probably realized this and corrected it in the -1001-
FSM. My .02....
And on related matter: Why the heck would a later manual as per your post, Ed, have a lower part number ??? -1001- versus -1007-. Stuff like that makes no sense....at least to me.:side: :silly: :S
- Becker
As far as charging goes I'm using a batteryless/starterless wiring harness that I'm making custom so that won't be a problem. Thanks for all your help guys I appreciate all the information. I'll go home and get my engine number so I can figure out exactly where it comes from.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
I noticed that too, and it doesn't make sense to me either. I did a double-take when I saw them. The manuals are original and haven't been torn apart or re-bound, so I guess it's just Ma Kaw's way of keeping us puzzled. Ed
- H2RICK
Well, Ed, it worked that way for me.....:S :blink: :silly: :lol:
- Becker
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
