- Thank you received: 225
CAM DEGREEING Removed...
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- keith1
Don’t let the title deceive you into thinking this write up being a parody of sorts for all the information contained within is basically excerpts from the camshaft manufacturers themselves and experts alike. I have spoken with numerous individuals that have considerable more knowledge than I regarding the subject matter, such as Larry Cavanaugh (Cavanaugh Racing heads), Plummen (truly, special gratitude to Larry & Plum), Timebomb, Mark1122, Sandy and Kawasakiman as well as others to pick their minds.
Basically I bugged the hell out of them until they gave me what I wanted to shut me the hell up!
members.cox.net/ruinsofstei/MOTORCYCLE%2...FOR%20DUMBPHUCKS.pdf
Hope it helps some others (Dumbphucks) to the process as I...
WOW...JUST FRACKIN WOW...nice job.....i gave it the quick read as its getting late here in little iceland, but you did a hell of a job...
i definitely have some reading to do.....
and that title.....i was having flashbacks of when i was a kid....untill i hit school i thought my given name was "goddammit dumbphuck" ...lol...seriously, nice job and you obviously spent a lot of time to benefit others...sticky of the year.....keith
- Sandy
- Fly High,Tony
- Thank you received: 13
Thanks for that,definitely worth phuckin saving.
Good one!
1977 KZ1000 A-1
- kawsakiman
- Thank you received: 6
but you spelled my name wrong again.
you need to omit the a after kaw.
kawasaki or kawsaki
who's the dumb phuck now? :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh: :laugh:
i saved it as well. great write up man!
- PLUMMEN
- Thank you received: 104
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
Isn't that the lobe centers? There is a big differance. I'm not sure that I am understanding correctly.
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
" Where it has extremely wide to extremely tight. Is the heading correct?
I believe the heading to be correct, copied directly from the www.webcamshafts.com/ ... Glossary
The way I'm looking at it is as follows...
Mind you, I'm by no way an expert and don't claim to be!!!!
Based on the lobe center separation and in the information directly above it Varying Lobe Center Separation it would be considered Tight due to short range of 104 to 114 lobe centers.
Example, the OEM KZ camshafts lobe center is 110 degrees thus Broad Power band, reduced cylinder pressure @ 8.5:1, reduced max torque, etc...
With the 105 cam I chose, I'm doing the opposite where I'm shifting my power band more to the low to mid range, increasing my max torque but I'm also increasing cylinder pressures @ 10:1 etc...
Basically, a little quicker off the line and especially at mid rpm range...
Excerpt for Webcam... Not all motors can handle the tight lobe centering due to the mentioned....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzz1p
I look at the closing point of the intake valve! To much cranking compression and you will be using race fuel. I like to lay out each possibile cam timing choice on paper so I can see it. The way I see it you have about seven timing choices.(advance both, retard both, advance int./retard exh., retard int./advance exh.,advance int./stock exh.,retard intake/stock exh.& stright up )You can find these choices on the net used by motorcycle drag racers, road racers and import car tuners.I have not seen anyone tune just the exhaust cam. Here is my example for three. I will use a stock Z1 cam.
L/C: Intake/Exhaust: Overlap: valve timing:
105* +5* / -5* 70* 35-65 / 65-35
106* +4* / -4* 68* 34-66 / 66-34
107* +3* / -3* 66* 33-67 / 67-33
108* +2* / -2* 64* 32-68 / 68-32
109* +1* / -1* 62* 31-69 / 69-31
110* stock timing 60* 30-70 / 70-30
111* -1* / +1* 58* 29-71 / 71-29
112* -2* / +2* 56* 28-72 / 72-28
113* -3* / +3* 54* 27-73 / 73-27
114* -4* / +4* 52* 26-74 / 74-26
115* -5* / +5* 50* 25-75 / 75-25
NOTE- If you find ANYTHING wrong with my homegrown hilbillie garage math "PLEASE, PLEASE" let me know so I can change my line of thinking.
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
Intake Cam
Exhaust Cam
Intake cam looks to be dead center, but the exhaust looks to be advanced quite a bit. These cams were on a ported head, with a 615cc engine that came in one of my parts bikes.
'85 GPz550(ZX550-A2)
- Z Krazy 1
I don't care how they do it in California
