- Thank you received: 1
heads
- HOGEATER
- Been riding 2 wheels since 1965,
26 Jan 2009 13:17 #260312
by HOGEATER
heads was created by HOGEATER
Is there a difference in deck height from mating surfaces of cylinders and heads to the top of the head where the cam roller mounts??? The reason I ask is , I replaced the head on my 78 KZ1000 LTD, with one from Ebay. The head had 32 tooth sprockets on the cams and my original head had 30 tooth, also when I place my cams in this head the chain is very tight and almost impossible to start the cam roller tower bolts. Since this engine has been bored to 73MM would it be possible for someone to shave enough from the base of the head to get more compression and also remove a link to compesate for the difference.
CHUCK
CHUCK
- PLUMMEN
- Thank you received: 104
26 Jan 2009 14:14 #260330
by PLUMMEN
Replied by PLUMMEN on topic heads
differant crankshaft center pin diameter.the big pin crank has a 16t center sprocket which takes 32t cam sprockets.the smaller more common crank has a 15t center pin to go with 30 t cam sprockets
- mark1122
- Keep twisting it
- Thank you received: 109
26 Jan 2009 15:03 #260350
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic heads
Did u understand what plum is saying?
Just use your old 30 tooth sprockets.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
26 Jan 2009 16:04 #260366
by PLUMMEN
hell i cant understand what im saying most of the time!:laugh:
- Thank you received: 797
27 Jan 2009 09:22 #260463
by 531blackbanshee
Replied by 531blackbanshee on topic heads
mark is right us the gears off of your old cams,on the new ones.or reuse your old cams and gears.
- HOGEATER
27 Jan 2009 14:22 #260500
by HOGEATER
Replied by HOGEATER on topic heads
I made the typical MURPHY.I put the 32 tooth cams in without checking or counting the teeth and got them to tighten down of course when I turned the engine over with a wrench it got out of time. I took those cams out and put my original cams 30 tooth sprockets and they wouldn't tighten down without a lot of tension on the cam chain. I'm going to remove the head again and check the cam chain follower sprockets to see if I bent them , that would be the weekest link and could bend before the chain or crank sprocket would break>
CHUCK
CHUCK
- KruZer
27 Jan 2009 16:00 #260517
by KruZer
*1977 1000, 1975 KZ998 LSR bike.
Replied by KruZer on topic heads
Since you turned the engine over with the wrong sprockets installed on the cams you better check your valves while you have the head off.....
Also check the cam chain follower in the front of the cylinder block. I think you're smart to look inside the engine before you try to start it.
I would think something would have had to bend or break for you to be able to get the cam chain on the sprockets and the top idlers installed.
Good luck,
Buzz
Good luck,
Buzz
- HOGEATER
28 Jan 2009 15:02 #260701
by HOGEATER
I didn't spin the engine over with the starter I just turned it real slow with a wrench, as soon as it jammed I stopped and backed it off and didn't try to turn it anymore. When I pull the head I'm going to check everything I can see for any bends.
CHUCK
CHUCK
- timebomb33
28 Jan 2009 15:19 #260703
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic heads
check the seal on the valves pour some varsol or kerosene down the ports when you get the head off you could possibly have bent the valves. if the cam chain is tight with the smaller sprockets double check that the cam chain is on the crank sprocket properly also make sure the tensioner is removed when installing the cams
