- Thank you received: 35
Questions about piston weights
- moneypit
and Ive got a 1000 set of jugs freshly honed and used pistons but the weights are a little off. is this a problem
The weights are .643 lbs,.635,.649,.649 I also checked my stock pistons which are .624,.624 ,.616,.623 lbs. I would think that it would throw off the balance of the engine if you get the rpms up. Yhe other thing I would like to know is about setting valves with the head off the engine If needed Ill start another thread. Thanks
2-76 kz900
St Paul MN
- steell
.643 lbs equals 291.659 grams
.635 lbs equals 288.031 grams
That's an approximate 6 gram difference between lightest and heaviest.
Personally, I'd try to make them all weigh exactly the same, but I don't know if it really matters or not.
- Thank you received: 2829
- trianglelaguna
- Thank you received: 235
If you plan to balance the weight of the pistons you may want to consider doing the rods too.
i got some advice in my thread on ring and hone stuff last week and someone had one grams out that had made the motor have a humm...he told me to try wheighing mine befroe installing and fileing or sanding any cast marks/burs on the heavy piston to bring it down in wheight...it is repeating info...but...may help
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- APE Jay
- Banned
- Thank you received: 58
Jay
- BSKZ650
- Thank you received: 14
bottom line get it close if you want, but I dont think your gonna see a dimes worth of difference
77 ltd1000, current rider
76 kz900, just waiting
- shighley
\'74 Z1-A, Bought new, worn out 3 times, being ridden now
\'83 XVZ12TK, was daily driver until frame broke
\'78 KZ650SR-D1A, Son's bike, I'm the wrench (He's young)!
- martijn
- moneypit
2-76 kz900
St Paul MN
- PLUMMEN
- Thank you received: 104
- moneypit
2-76 kz900
St Paul MN
