- Thank you received: 10
Questions about piston weights
- timebomb33
23 Jan 2009 14:10 #259697
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Questions about piston weights
underneath the piston crown and make sure you don't take it away from the pin boss.
- mark1122
- Keep twisting it
- Thank you received: 109
25 Jan 2009 07:52 #260057
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Questions about piston weights
J & E. pistons come within 2.5 grams.
i had a piston out 8 grams and felt a buzz at 3500 rpms.
you may as well get them closer while there on the bench.
I have seen an extra oil hole added to the wrist pin boss for better oiling. so that is were i removed the material. I just started drilling an extra hole in the pin boss, untill the extra wieght was gone.I had to go through to the other side of the boss a bit on the heavey 1.Or u could just restart with a biger bit .
Hope this helps.
Hope this helps.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- PLUMMEN
- Thank you received: 104
25 Jan 2009 08:08 #260060
by PLUMMEN
Replied by PLUMMEN on topic Questions about piston weights
make sure you get rid of any burrs when drilling those oil holes,your wrist pins will thank you later! :laugh:
- mark1122
- Keep twisting it
25 Jan 2009 09:07 #260068
by mark1122
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
PLUMMEN wrote:
Very good point.
I noticed that my new J&E pisons dont have these holes. Instead, they have a hole drilled in the oil ring groove ,that leads to the wrist pin boss. Nice, this puts a bit of presure behind the oil to force feed the pin.
Very good point.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- moneypit
- Thank you received: 35
26 Jan 2009 20:32 - 26 Jan 2009 20:33 #260413
by moneypit
2-76 kz900
St Paul MN
Replied by moneypit on topic Questions about piston weights
Heres the other posible issue I have with these pistons Fact is this is why I weighed them these are 1000cc
1 of the 4 has a different skirt than the other 3 but is lighter. And I never remember a buzz in the motor before
with the stock pistons which were a little different in weight also
2-76 kz900
St Paul MN
Last edit: 26 Jan 2009 20:33 by moneypit.
- PLUMMEN
26 Jan 2009 20:44 #260415
by PLUMMEN
looks like somebody swapped 1 out at one time in the set.
- moneypit
26 Jan 2009 21:13 #260421
by moneypit
2-76 kz900
St Paul MN
Ebay purchase When they arrived 1 had been dropped pinning the rings so he sent a replacement does anyone think there is a problem with skirts or just the weight issue
2-76 kz900
St Paul MN
- PLUMMEN
27 Jan 2009 05:40 #260442
by PLUMMEN
i dont think the motor will notice the skirt design as long as its not too short to where it makes piston rock.
