- Thank you received: 2
small issue...need input
- keith1
my first inclination is to adjust cam chain to rule that out..i didnt do that part, as my second set of hands did that part as i was slowly turning motor...so, i will do that to rule it out ...if it doesnt end up being that, should i be thinking carb synch?....i pulled bowls and tops and did some experimental jet work and polished (somewhat) tops, but i didnt mess with any adj other than replace pilot screws
on bottom of carbs......any ideas? thanks
- PLUMMEN
- Thank you received: 104
- keith1
check cam chain tension and or synch carbs would be a starting point.
thanks...i hope one of the two does it...i ll be swingin if its just the chain.....
- Thank you received: 2098
With ign switched ON (engine not running), what is measured voltage at coils?
Is oem points ignition being used?
What is condition of battery and state of charge?
Has ignition timing been checked with strobe type timing light?
Has spark quality at each plug been visually inspected?
Have carb float bowl fuel levels been checked using the clear tube method?
Has compression test been performed?
Are valve clearances within specs?
If not already done, would address above matters to eliminate other possible deficiencies before syncing carbs.
Good Luck!
- PLUMMEN
- keith1
A few questions, please.
Good Luck!
fresh top end with mtc pistons 10.5 to 1 comp, fresh jugs, refurbished head with 3 angle cut, valves blast beaded, new guides , new oil seals,
stems trimmed to length, andrews 2x cams, top end shimmed by builder/machinist, new cam chain, all new guides and rollers......im guessing compression and leakdown should be within spec...dyna ign and new accel coils and wires...battery good....
had same problem after rebuild with old coils...so we can probably rule them out...
carbs were fine on old motor/top end....just thinking i might have overlooked something stupid/obvious......thanks
Good Luck!
While the low rpm noise may indeed be resulting only from an improperly adjusted camchain and/or out-of-sync carbs, where possible issues have been ruled out as to compression, spark quality, and battery condition, other remaining possible issues would imo include:
Voltage reaching good coils;
Ignition timing;
Float bowl fuel levels.
If camchain adjustment and carb sync fail to resolve the low rpm noise issue, would address the three areas noted, and then re-sync the carbs.
As known, carb performance at top end doesn't significantly relate to lower rpm performance governed by the pilot circuit.
Good Luck!
- keith1
if it isnt the chain, those carbs are going off to george faster than you can say "clean and right".....with an 8 week lead time , i want to be riding first weekend in april thats nice........no sense going for the dirt nap with your pockets full, wont do ya any good....lol...
- keith1
Good Luck!
Ignition timing;
Good Luck!
thanks....i ll report my progress.....
...While the low rpm noise may indeed be resulting only from an improperly adjusted camchain and/or out-of-sync carbs, where possible issues have been ruled out as to compression, spark quality, and battery condition, other remaining possible issues would imo include:
Ignition timing;
If camchain adjustment and carb sync fail to resolve the low rpm noise issue, would address the three areas noted, and then re-sync the carbs....
If not already addressed, spark quality should appear in the list of other remaining possible issues.
A good healthy fat spark at kick-over usually indicates adequate voltage reaching the coils. But it's best to actually measure the voltage.
Forgot to earlier mention --- would also test voltage across battery terminals at idle (look for 12+ volts) and at 4000 rpm (look for 14+ volts). Thinking any deficiency in charging system may produce insufficient voltage at idle rpm (perhaps drawn down by headlight) and thereby less than proper spark needed for best combustion.
The Dyna ignition is known as being a voltage hog, especially at lower rpms.
Good Luck!
- timebomb33
I THINK MY POWERBAND BROKE
- PLUMMEN
no danger of that happening to me i work very hard at staying broke!:laugh:PLUMMEN wrote:
