- Thank you received: 235
Exhaust gaskets
- trianglelaguna
as patton said for sure... order of assmb...and proper fits are the #1 start point...and his paragraph above better words my thinking,,, on my statement,,, about the collers small chance of being flopped backwards...the flanges would not sit in their tracks.....good luck...now you gotta tell us what it was...craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- LukeJ
This is with no pressure on the collar
Pushing collar - gives you an idea on how much movement there is
How this one is supposed to be the way the collars fit. The correct way is how my hand is holding it all together?
The one on the left is just to show that the collar doesnt fit all the way around the flange.
And heres one of the project. Its my first project bike ever so I apologise if some Z purists find it ugly lookin. Its a work in progress and it looks a billion time better than what it did when I got it.
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- HerrDeacon
If you need a pic let me know and I'll go out to the garage and snap one.
- Kawickrice
but a not so subtle flash
Being that the collars are backward would explain the flash.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- dman3998
dman
Dman
SE Idaho
"Smart only goes just so far, STUPID is UN-limited"
79 KZ1000 LTD
Honda XRL650L
Yamaha RD350B
Yamaha DT400B
- Thank you received: 2098
Assure the old exhaust gasket is removed. Sometimes there are two old gaskets in the same port where reassembled without new gaskets. The old gasket is often difficult to see all crusted inside the port.
Would always use new copper crush gaskets.
With exhaust clamps hanging loosely around header pipes and new copper gaskets fitted inside the head recesses (a dab of hi-temp sealant helps hold them in position), hold the headers in place on the head against the gaskets, and fit a pair of split collars onto each header pipe with the small non-flared ends of the split collars toward the engine to press against the flared ends of the header pipes. Use masking tape (or rubber bands) to hold the split collars in place during assembly. The flared ends of the split collars fit into recesses in the exhaust clamps. While holding everything in position, loosley start the clamp holder nuts onto the exhaust studs, and assure all parts being properly fitted and aligned before tightening the exhaust stud nuts against the collars.
The clamp will crack or break when tightened unless all parts are correctly fitted and aligned.
Clamps press against split collars.
Split collars press against header flanges.
Header flanges press against copper gaskets.
Good luck with the installation!
Run Run Run
Run Spot Run
See Spot Run
:laugh: :laugh: :laugh:
Just razzing ya for less than careful reading of the earlier responses. :woohoo:
Many prefer using rubber bands --- "Smells like victory!"
[youtube][/youtube]
Good Luck!
- RonKZ650
- Thank you received: 240
When I pulled my pipes off the split collars had the fiberglass strand residue of fiberglass packing tape. I am guessing the last time they were put on the PO used that to hold them on for installation. does this sound like a feasible methode?
dman
Sure you can do that. Doesn't matter what kind of tape because once the pipe is installed you no longer need tape. Use fiberglass, black electrical tape, even scotch tape.
If the collars happen to be too short I wouldn't recommend using double gaskets. If you look at the port the pipes plug into there is only a small distance available for the pipe to slip into and using dual gaskets will completely fill the port. Chances are very good when you tighten the pipe it won't be 100% in the port and will be tightened down to the surrounding head casting and not in the port. No seal at all when that happens. Do as you see fit though, if it works that's fine.
- LukeJ
Gasket - Split Collar - Header - Clamp
When it should be
Gasket - Header - Spilt Collar - Clamp
I know Im new at this, but it seems a really fiddly way of fitting an exhaust!
Heres a pic of all the new shiny painted stuff I picked up off the spraypainter today.
*** EDIT!
I know what the problem is. The set of headers that came with the bike had a flange which was essentially just a curled lip at the end of the pipe. The set of split collars would make up the rest of the distance to fill the space to make the clamp useful.
The headers I am using have a flange that is about 2/3 of an inch long. Put the split collars onto the flange and the collars are too long. All I really need is a set of short collars. Would cutting my existing ones to size be the best option?
- timebomb33
I THINK MY POWERBAND BROKE
