- Thank you received: 540
Exhaust gaskets
- MFolks
The split "Keepers" I hold in place with some masking tape.
Both the grease and tape will smell a little for a while but will burn off with no problem.
- LukeJ
Personally, I like the idead of having shorter collars than longer studs.
- trianglelaguna
- Thank you received: 235
I had a word to an exhaust guy in town and he said I could just get some longer studs for the engine so that I wouldnt have to go looking around for shorter split-collars.
it does not sound like your having fun????becuase this is most important...now that we got that solved....do not change your exhuast studs yet...let's think this through...with the other folks help too....can you post a side shot of the top of one header pipe showing the flanges that go into the exuast ports????the ones that are 2/3 of an inch thick...i am lost at that point and think we are onto somthing fishy again...the studs are prob stock and fine...the header should be fine too...what was it for...get a part # off the header and go online and find it's application....the studs will either come out nice or much worse problems could arise...avoid that fix...my 2 cents...get used nice header for your model of e-bay or the guys here may be where i'm headed...look for a picture of split collers online for your bike and com[pare to what you have in your hand...ect...ect..somthing is not right maybe in your parts and needs changing...then future work will not have to do the hokey pokey to compensate...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- trianglelaguna
...yeah they wont even see you coming...just don't paint the motor or kickstand yellow too....hhahahahaahahahahaahahaahlooking good i like the colors that shouldn't attract any extra attention should it
1976 KZ900
2003 ZX12R
2007 FZ1000
- LukeJ
Two headers are better than one, as they say. The black header is the old one. It is cut off at the 4-1 joint its badly bent. The flange is merely a bump on the end. This is the header the bike came with, but I doubt its original.
The chrome header is in much better condition and is ready to go. The flange on it is approx 2/3 inch LONG (not thick, sorry).
Here is the problem. Flange and split collar = too long for the clamp to atach to the studs.
Do I cut them down or would a bike shop happen to have shorter ones? Thankyou for the advice thus far.
- trianglelaguna
Here are the pics.
1976 KZ900
2003 ZX12R
2007 FZ1000
- keith1
i m not sure you have a correct replacement header...
sending link...hard to see in pic and its a mac, but the big thick flanges on your pipe might not be correct....
webhosting.web.com/imagelib/sitebuilder/...0Black/Chrome1977-85
just trying to help you out....if those collars are correct, pipe is wrong....you might have to spend some time researching....good luck.....keith
- Thank you received: 2098
Then cut (shorten) the collars whereby they will afford the exact same measured distance when fitted to the long flange headers.
Good Luck!
- LukeJ
- gpzrox
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- LukeJ
I've looked at Kerker and MAC - are there any other exhausts that will work on this bike?
- trianglelaguna
Out of idle curiosity, which exhaust produces the most insane sound?
1976 KZ900
2003 ZX12R
2007 FZ1000
