Piston to head clearance
  • mark1122
  • Topic Author
  • Keep twisting it
30 Dec 2008 09:36 #255364 by mark1122
Piston to head clearance was created by mark1122
Piston to head clearance, or squish.
There seems to be different opinions on what this clearance should be.
My local builder says i can get away with .040" .
Paul Gast says i should go for .048" to .053".
What I'm getting out of this is i can get away with .040" but if i get pre ignition i may have to adjust cam timing .(= larger lobe centers= less torque.)
It seems to me that the tighter the squish, the more turbulence u have to get a better burn and prevent pre ignition. And at the same time it will raise cyl temp and promote pre ignition.
I ran about .050" successfully, on my last 1135cc build. That will be my target for my currant 1200cc build unless you wise men change my mind.
If i go with more clearance i will not have timing issues. Less clearance = less than 1 HP gain.
Does anyone have a Minimum number that they can back up with experience?
What is your opinion and why.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
30 Dec 2008 12:22 #255384 by BSKZ650
Replied by BSKZ650 on topic Piston to head clearance
.040 is pretty tight, also what about valve to piston, sems that would be very close also,
77 ltd1000, current rider
76 kz900, just waiting
  • mark1122
  • Topic Author
  • Keep twisting it
30 Dec 2008 12:36 #255390 by mark1122
Replied by mark1122 on topic Piston to head clearance
The valve to piston clearance should be fine with my little .425" lift cams. It was before.
I will be sure to recheck all clearances when my new pistons and block arive. Thanks for the heads up though.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
30 Dec 2008 20:47 #255468 by steell
Replied by steell on topic Piston to head clearance
Speedomotive (long time hot rod motor builder) has a lot to say on the subject.
www.speedomotive.com/t-showbymodel.aspx
30 Dec 2008 21:34 #255478 by 77KZ650
Replied by 77KZ650 on topic Piston to head clearance
.035 to .040 on something thats not going to be over revved .045 if you think you may miss the odd shift
forged pistons run loose in the bore untill they are up to temp compared to cast pistons. so allow a complete warm up before thrashing on it or your pistons can tag the head if they rock in the bore if they are cold and you are running really tight clearance
make sure the rods are ok (good idea to have them resized if they are showing an egg shape in the big end) and make sure the rod bearings are correct. too loose and you may get pistons touching the head
07 MDP Rookie of the Year
31 Dec 2008 00:39 #255488 by nads.com
Replied by nads.com on topic Piston to head clearance
I read the speed article and understand now what I wanted to know, thanks steel. Ill measure quench from the top and the sides of the piston and find a medium for my motor. Mark your engine has diff. measurements so I can't answer your question but> The pre ignition part of the article tells me alot about how to set your timing, with me it's built in from memory and markings but mostly by the way the motor revv's. I try to make the motor run as strong as poss. without having a handful of timing thrown in there. It needs to be able to breath through the power band. That being said I think it's best to combine the two adjustable areas for a mighty fine ride. I'm working with 170-180psi so thermally my engines burn charactoristics are not adjusted by the same parameters as yours would be. But knowing how this fuel behaves is just bitchen. Bartender, hand me another one...:blink:
31 Dec 2008 10:22 #255537 by mtkawboy
Replied by mtkawboy on topic Piston to head clearance
If Paul Gast said it you can take it to the bank. Hes been building motors longer then most people on here have been alive
31 Dec 2008 11:32 #255542 by PLUMMEN
Replied by PLUMMEN on topic Piston to head clearance
id stick with the .050,i pushed the limits years ago and it cost me a brandnew motor with less than 50 miles on it,i did manage to save the 73 z1 engine cases but crank ,pistons and head were destroyed in the process!:S :blink: :unsure: :ohmy: :huh: :dry: :( the motor was built for a hot streetbike but i somehow got talked into putting it into a dwarfcar that needed a motor.it would of been fine in a motorcycle but sitting sideways in that dwarf car with little airflow to #s 1 2&3 brought out expansion issues and took it out hard!but it was smoking every car on the track for like 9 laps before it let go!:woohoo:remember dragbikes that only run a 1/4 mile at a time and get cooled off can get away with a lot more than a streetbike ridden all day in traffic B)
31 Dec 2008 18:27 #255600 by davel
Replied by davel on topic Piston to head clearance
Excellent article! Thanks.
  • mark1122
  • Topic Author
  • Keep twisting it
02 Jan 2009 15:45 #255805 by mark1122
Thanks Steel. That was a good read.
Thanks for all the input guy's. It seems i can run .040" but i will likely go with .050".
My block and pistons should go in the mail to me, mon or tues from Fast BY Gast.B)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mark1122
  • Topic Author
  • Keep twisting it
03 Jan 2009 04:45 #255865 by mark1122
What is the piston to head clearance on a stock KZ?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
04 Jan 2009 13:01 #256150 by martijn
Replied by martijn on topic Piston to head clearance
I read the article of speedmotive but it did not give actual answers on cam timing and measured compression. I did not understand in the article about knocking 10 degrees after TDC while ignition is 30-40 degrees before TDC.. even retarding will not go beyond the TDC.
Did I miss something??
