- Thank you received: 2098
KZ 750 H3 - Valves and Compression
...procedure for checking or changing the valve shims for the FOURs....
Allow engine to completely cool. Overnight is best.
Remove points cover.
Remove fuel tank.
Remove valve cover.
Measure with feeler gauge between bucket and cam (lowest side of cam is supposed to have factory prescribed gap between it and bucket).
Use 17mm wrench on fake "nut" (the larger nut located underneath the points cover) for turning the crankshaft by hand (clockwise in its normal direction of rotation) to align the low side of cam with the bucket being measured. Don't go backwards. If go too far, keep turning forward again. And don't use the smaller bolt head that screws into end of the crankshaft (which holds the advancer in place) because doing so risks stripping the threads or breaking the bolt.
Keep clearly written notes of the existing gap measurements for later reference.
As known, other things besides jetting may cause evidence of too lean condition inside cylinder, such as too low fuel level, insufficient fuel supply, improper spark plug heat range, air leak, air filter issue, etc.
Thumbs up on rehabbing the carbs. But once is enough (when in the home stretch), even with delectably soft new intake hoses. :lol:
Good Luck!
- WBPDX
- 1983 KZ750 H3
Removing the cover has been a BEAR. The screws holding the coils are absolutely stuck. I tried everything. I came inside to charge up my drill batteries for drilling off the caps, and to grab my impact gun... What should have been a quick project is turning into an all afternoon afair, as usual. :laugh:
- WBPDX
- 1983 KZ750 H3
Here is what we have for valve clearances. I think I need a finer feeler gauge set? The smallest I have in either of my two sets is .038mm
Anywho.
I am providing corresponding compression numbers as well.
120 PSI:
.038mm Intake - Less Than .038mm Exhaust
60 PSI:
Less Than .038mm Intake - .152mm Exhaust (WOW!)
45 PSI:
Less Than .038mm Intake - Less Than .038mm Exhaust
110 PSI:
Less Than .038mm Intake - .06mm Exhaust
These are ALL really bad, aren't they? Is the spec .08-.18mm? If so, I have ONE valve that is within spec!
Bikebandit lists having a ton of shims in stock... is that where I should order since Z1E is out?
- bountyhunter
- Thank you received: 337
Be very careful torquing the cam cap bolts. many have been stripped. I think the spec is about 8 ft-lbs or 100 inch-pounds. I suspect most were stripped using a torque wrench with no accuracy at that low range. Get a transmission torque wrench with 200 i-p full scale and you won't strip them. I got one at Harbor Freight tools pretty cheap.I concur with suggestions of OKC_Kent about reading up on the procedure. Especially about correct re-assembly, and how best to avoid stripping out threads in the cam bolt holes.
Good Luck!
- bountyhunter
- bountyhunter
The smaller shims for the fours are available everywhere, it's the larger shims for the twins which have no new sources. Do a search for "valve shim kits" and you will find them. They sell kits that have a ton of shims of all sizes.Is there another source for the shims other than Z1E?
- bountyhunter
If the thinnest gauge you have is .038mm and you can't get it under, you don't know what the clearance is. It could be zero. Until you install thinner shims and get an actual clearance reading, you can't calculate the shim you need.
.038mm gauge is thin enough to set valves, the smallest speced clearance is about .05mm. The thinnest gauge I have bought is .001" which is .025mm if I did the math right. The .038mm gauge is .0015".
I think they have good prices, I have bought stuff from them. These shims are pretty common, you might be able to go to the dealer and swap some instead of buying a bunch.
- WBPDX
- 1983 KZ750 H3
I did NOT re-tourqe the camshafts. Luckily HF is 5 blocks away... I'll get a smaller-scaled torque wrench and check.
I just re-checked the clearances, I found one mistake I think... and I wanted to try giving the motor more time to cool, and checking to see if the buckets spin:
120 PSI:
.038mm Intake SPINS - Less Than .038mm Exhaust SPINS
60 PSI:
Less Than .038mm Intake Does NOT SPIN - .152mm Exhaust SPINS (WOW!)
45 PSI:
Less Than .038mm Intake Does NOT SPIN - .068mm Exhaust SPINS
110 PSI:
Less Than .038mm Intake Does NOT SPIN - Less Than .038mm Exhaust SPINS
As if all this wasn't fun enough, when I took off the points cover, there was a busted up spring, and what looked like part of the advancer assembly sitting loose, wedged in the cover! The messed up thing is, I can't find ANY of these parts in the fiches. Whats going on here?
- WBPDX
- 1983 KZ750 H3
Right now my shopping list is:
-Manual
-Shims
-Carb boots (maybe)
-Advancer (eBay)
-Complete gasket set (Or just headgasket and valve cover)
How intelligent would it be to buy a used head for shim-swapping, and in case I have a REAL valve problem? For the cost of 8 shims, I can probably buy a used head...
What are the odds that my rings are worn, and is there a source for reasonably priced standard size rings?
- gane
- Thank you received: 1
[img][/img] 1977 KZ1000A1
...my shopping list is:
-Manual
-Shims
-Carb boots (maybe)
-Advancer (eBay)
-Complete gasket set (Or just headgasket and valve cover)....
Imo, chances are reasonably good that setting valve clearances to specs may resolve the compression problem, and without any need to remove the head.
- WBPDX
- 1983 KZ750 H3
For now, I am going to order:
- Manual
- Valve cover gasket
To at least get the party started.
Thanks for all the info guys.
