- Thank you received: 4
1075 Kit Questions
- freebyrd24
if they are the wrong jugs, can i make them work or is it completely wrong and unsalvagable?
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- freebyrd24
Sold:
- austin3119
- Thank you received: 7
Of course I have no engine building skills whatsoever.
- saxjonz
- KawboyZ
- Thank you received: 76
Well, ... The J motor 998 and Z motor 1015 are different for sure. The z guys take the J heads and mate them to the z blocks as they can mate them to higher compression pistons and lower the compression by one point but more so because the j motor head I think has slightly bigger valves but it breaths better and you would have to buy an adapter kit which requires some modification to head. I say go to www.kzzone.com and have a look see. You can call the techs. Jay would know the best route for sure.So I picked up a new set of cylinder jugs all bored and honed for the 1075 with pistons and everything i need. I am about to put the jugs on but noticed the markings on it are 1.015 instead of 998 like the original cylinders that came off. Is this the different model jugs? I have no idea how to put the front cam chain guide in and now im pretty worried. Do I have the wrong set of jugs? How do I get the front cam chain guide in? Real real concerned now, looking for some quick answers as i have a couple friends over to help today and now we are puzzled. thank you
But I would be banking on the talking to whoever sold you them and seeing about getting another block or having yours bored to 1015 if it is possible as you will spend money on the adapter kit which I assume that you are looking to save money right?
79 LTD B3
- APE Jay
- Banned
- Thank you received: 58
- freebyrd24
Sold:
- saxjonz
- KawboyZ
Jay has an explanation of the differences of the compatibility between the j and the z so check his site out and read the article it may help you. I am a noob myself. I have torn my engine down with the supervision of a pro who has done this all his life and really knows his stuff. I could ask him if no one else gets back to you before that.
79 LTD B3
- APE Jay
- Banned
- freebyrd24
Sold:
- freebyrd24
www.overstockpartsgalore.com/engine1007.html
I think it was Keith that said he also had a bad experience at first with this place as well until they finally got it right. They did not clarify which motor they used the block from, unless I was mistaken, and I recieved the 1015 cylinder for my 998. They wouldn't exchange it for a 998 though they said they could do the 998 if I bought another one from them for full price. I can understand thought that they are a low buck place and can't afford to stock the 1015/1075 kit, but that didn't help my situation.
I finally sold the 1015 one and then reluctantly tried to e-mail them again and get a 998 kit but they refused to answer multiple e-mails.
If they get it right, it seems to be an okay place with a decent product. But if not your in for a world of hassle and issue until they do get it right. But I think once they do its okay.
Just sharing my experience. Maybe it was me, but just thought I'd put it out there.
I called around to some machine shops and found some pretty good deals surprisingly! So I just ordered a 1075 piston kit and it is on its way! I'm very excited!
Sold:
- keith1
- Thank you received: 2
Hey everyone sorry for the delays and panic and confusion. I had a very bad experience with this place...
i think it was old man rock that had a problem there,but i could be mistaken...
- Old Man Rock
- Thank you received: 225
Let's see, oh that's right...
MRE does their machining!!
Ah well, Tony bought one of their kits as well and had no problems...
Same time, it's a good deal where I had to obtain a clean (no broken fins) cylinder as it was so frustrating oh most definitely... but now that's it finished and since I've run into head aches with every single purchase from a Florida web based supplier (not joking, everyone of them) it just seems to be the way it is these days...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
