- Thank you received: 4
1075 Kit Questions
- freebyrd24
I want a 1075 kit for about 90% street use and maybe 10% strip. Thats a generous 10% too, itll be a street bike and I need reliability. What are there for kits out there? Do I see 1075 kits with higher CR's as well as ones with lower CR's. Wheres the best place to get the streetable 1075 kits?
When I have to do my boring, I just have to get the jugs bored correct?
I'm not new at all to motors and mechanical work, just new to the insides of a KZ.
What should come with these kits? Just the pistons? rings too?
Thanks everyone, any help would be incredible!
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- keith1
- Thank you received: 2
Hey everyone, I've been slowly diving into my 1981 kz1000 ltd project and hit my first round of questions here. I got the jugs and head off today and the jugs look ok, but one has some scoring in it that I'm worried about. I've been searching for some info on the 1075 kit and have some questions.
hi,
look around , 1075 kits are abundant...i am installing one with 10.5 compression and i grabbed a set of used andrews 2x cams....my head is being redone as i write and i cant wait to get it back...looking at bike 1/2 apart is getting old..all the piston kits come with piston rings and circlips or buttons ...depending on where you get it, also base and or head gaskets...your jugs
if decent should need just bored to 1075..APE sells packages with cams.....i got my stuff (mtc pistons, buttons, gaskets, redone jugs with a new finish,jugs all bored and matched to pistons) from florida....you have a lot of options where to go and who does what.....do your research, ask a lot of questions if need be , and good luck....keith
- keith1
hi,
heres where i m at so far....
- Old Man Rock
- Thank you received: 225
It's not going to surprise me who's doing your head work.... Mine on it's way back!
Some of the best prices I've found...
dynoman.net/engine/pistons/kawa.html
Cylinder Modification & Replacement Parts
All replacement pistons are sold complete with Piston pin, Retainer Clips, and rings
1075cc
Dynoman $419.95
2.835" or 72.00mm 2.5mm oversize
Stroke - 66mm K1076 10.25:1 Cylinder boring only
Piston: 4548M07200 Rings: 2835XC Piston Pins: S523
Retainer Clips: CW17 CFM20 Head Gasket: W3918
Optional Base Gasket: W5026
If you want to keep your cylinder in tack, an additional $100 this kit includes the already bored cylinder, no broken fins... ~ $600.
www.overstockpartsgalore.com/engine1007.html
Just keep in mind, cylinder boring/honing per hole is ~ $80 these days... Some have found even cheaper but that seems to be about the going rate.
Good luck and don't forget, images are a must!
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
@ Keith... Mine looks the same! :laugh:
1075cc
Dynoman $419.95
OMR
nope not the same..i have a LOT more polishing to do to make mine look like that!!!!:laugh:
- freebyrd24
OMR, you have a ton of time into that motor and it looks incredible! and that link you sent for the 1075 with cylinder, pistons, etc..... that looks like a sweet deal. That should be everything I need correct? I definately should go that direction as I broke a couple fins already! I started a project thread last week, but so far it is all disassembly. I'll definately keep the camera ready when parts come together little by little!
Sold:
- Old Man Rock
Ouch....
Even if the fins where good I'd go this route due to the $80 a hole x 4 = $320. For an additional $100, I get the hole shubang, already bored!
Everything is there... Cylinder (bored & honed), pistons, rings, wrist pins, clips, gaskets (base & upper)
NOTE: I did have some issues in dealing with these guys at first but they made it right! Several posting on the subject...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
Keith1, I think that your motor looks incredibly clean. i love how that looks like that!
keep us posted , with pics of course...good luck...
- freebyrd24
Sold:
- Old Man Rock
I'm probably the wrong person for this due to I blew a hole in my engine case...My own dumbass doing mind you but here goes.
In answering your question, yes unless you are the original owner... Plain and simple due to not knowing the history of my bike, nor what had happened to it in the 25 years it sat, nor how it was riden and taken care of, by all means I had to split the cases and visually inspect and repair any damages.
Same time, I was replacing the timing chain (endless chain) and splitting the cases is required in accomplishing.
In doing so, I found that my shift forks where catching on the shift drum slots, so I replaced. Sure I could of probably got by but for what I had invested in the project... a little piece of mind was worth it...
Just my two cents worth, ok all, rip me apart! :laugh:
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- freebyrd24
Sold:
- Exitpupil
stores.ebay.com/Pit-Stop-Performance-Store
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
