- Thank you received: 235
motor sitting for 9 years
- trianglelaguna
I think this motor could be a runner ..cleaned up -oil changed ..re timed..and made to run?
i wonder if i would strip the timing bolt to try and rotate the crank assm. or if i should try to bump it in gear first to break the cyl corrosin from the rings????..it's on my bench now???not in the bike...???peace Craig
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- PLUMMEN
- Thank you received: 104
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- rodneyo
- bountyhunter
- Thank you received: 337
There is a penetrating oil called Kroil which is the greatest for getting under rust.id dump some oil/tranny fluid down the plug holes let it sit a little while and use the kick starter by hand to turn it over real easily.
- Thank you received: 2098
There is a 17mm "fake" nut purposefully there to use when hand-turning the crankcase to align the T mark on the advancer with the permanent timing mark on the case whenever top-dead-center positioning is desired. But even this 17mm nut is designed for hand-turning a non-frozen engine. And I would not use the 17mm nut either in attempting to break free a frozen motor (presumably piston rings rusted to cylinder walls). But am thinking the 17mm "fake" nut is replaceable if damaged by excessive torque.
Good Luck!
- trianglelaguna
I guess i'll wait a while and see if time and some more pb can work some magic.
I found a complete versah gaskett kit in the boxes that came in the deal -so maybe a tear down and a bump in bore and piston wpould be the right thing to do. peace craig
1976 KZ900
2003 ZX12R
2007 FZ1000
- wiredgeorge
- trianglelaguna
the broken fins are to be avoided. i thank you for your responses...and i am in possesion of a used clean big bore kit and block set that i got a while back for my 76 pretty cheap.I may just see what size it is and find out if it will work on this z-1 since my 76 is running still and i ride it and the z-1 is out on my bench..i want to have everything ready to go before i start taking the z-1 apart so i don't waste time before putting it together and loose somthing or forget whats what...more questions to follow i'm sure peace crakig
1976 KZ900
2003 ZX12R
2007 FZ1000
- mark1122
- Keep twisting it
- Thank you received: 109
Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
I would try to be patiant and let it soak for a week . Then try the kick start again , before a tare down.The bolt on the other end of the crank is too small to use as well, but u could try a chain wrench around the stator.
Good luck.
Or maybe a rubber belt style automotive oil filter remover tool.
- trianglelaguna
there is allmost no carbon on the pistons but they have been soaking so who knows there...BUT...the rings in three of the cylinders have gone to town with mother nature...the head came of clean and the valve gaskett,cam chain o-ring, and head gaskets looked brand new...my girl waited for two hours longer for dinner so i had to call it a night but i was ready to try and gently!!!!!!!pry the block up..i put some p.b on the cylinders and scraped the rust rings a little then re sprayed,, tomorrow i'm gonna start tapping/prying...peace
1976 KZ900
2003 ZX12R
2007 FZ1000
