'77 KZ650B1 cam seating issue
- Nate77
23 Nov 2008 16:52 #249037
by Nate77
1977 KZ650 B1
'77 KZ650B1 cam seating issue was created by Nate77
Hey, I'm having trouble getting the notched (right) side of my exhaust cam seated when I try to line the "T" level with the head in the front. The ignition is set at 1 & 4 TDC...should the ignition be lined up with the T or the mark in between the T & F??...The manual really doesn't say.
I have installed Dyna S electronic ignition.
There also seems like there's no slack in the cam chain. I'm pretty positive the chain is on the crank sprocket. Any suggestions? Thanks
1977 KZ650 B1
- PLUMMEN
- Thank you received: 104
23 Nov 2008 16:57 #249039
by PLUMMEN
Replied by PLUMMEN on topic '77 KZ650B1 cam seating issue
is the tensioner removed?
- Nate77
23 Nov 2008 18:57 #249054
by Nate77
1977 KZ650 B1
Replied by Nate77 on topic '77 KZ650B1 cam seating issue
Yes, the tensioner is out. The #3 lobe appears to be hitting on the shim bucket, not letting it sit level on the head. I could turn the shaft however many teeth it takes to sit level but the "T" mark on the sprocket won't be level with the head.
When the ignition timing is set, what needs to match up to the fixed timing mark?...the actual "T" or the line between the "T" and "F"??
1977 KZ650 B1
- fixer5000
- Thank you received: 5
24 Nov 2008 01:01 #249109
by fixer5000
1978 kz650b pretty much stock
massachusetts
Replied by fixer5000 on topic '77 KZ650B1 cam seating issue
is your tach drive keeping it from falling into place??
massachusetts
- rstnick
- Thank you received: 377
24 Nov 2008 06:09 #249126
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic '77 KZ650B1 cam seating issue
Did you have the cam gears off the cams?
If so, you may have re-installed the exhaust gear 180 degrees out.
No lobes should be be pointing down during re-installation.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- RonKZ650
- Thank you received: 240
24 Nov 2008 07:21 #249136
by RonKZ650
Replied by RonKZ650 on topic '77 KZ650B1 cam seating issue
Of course you need to tighten the cam caps, and the cams will settle in place and you'll have your slack. No way the cam can ever lay flat until you fully install. So line the T mark up on your advancer, look at the arrow on the exhaust cam and visualize where it will line up when the bolts are tightened, torque the cam down enough for it to be fully seated, look at your arrow and if you've guessed wrong by a tooth or two, go back and redo. After the exhaust is lined up, count back your 36 teeth and line the intake cam there, torque the intake cam, then press down on the chain between the cams to get enough slack to install the center idler sprocket, turn the engine clockwise slightly to take slack out, then install the tensioner if it's been removed, turn the engine over 1 revolution to the T mark and see both arrows lining up correctly with the head. There is no reason to ever remove the tensioner when removing the cams because on pre 1979 manual tensioner it will stay set right where it was, on 79-up lock the tensioner as instructed in the manual.
- PLUMMEN
24 Nov 2008 09:09 #249148
by PLUMMEN
ah!:laugh:
- Nate77
24 Nov 2008 15:10 #249189
by Nate77
1977 KZ650 B1
Hey guys, thanks for the helpful replies...I worked on it this morning and finally got the timing right. I guess I skipped the "36 pin" rule from the manual. I was trying to snug the exhaust cam down and THEN set the intake cam in place instead of alligning them at the same time. The bike's running like a champ! Thanks again for the advice!
Nate
Nate
1977 KZ650 B1
- Nate77
25 Nov 2008 12:46 #249310
by Nate77
1977 KZ650 B1
Well, I took the bike out again today for a more serious ride after timing the engine and it seems like it is losing power in 3rd and 4th gear. It even sounds different (from the exhaust pipes). I didn't notice any exhaust leaks...carbs are fine...any ideas?
1977 KZ650 B1
- Bdog
- Sweep the leg johnny!!!
- Thank you received: 9
25 Nov 2008 14:39 #249322
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
Replied by Bdog on topic '77 KZ650B1 cam seating issue
Points, coils, electrical? Look at those, the motor would have gone bang or felt real weird if it was inside.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- RonKZ650
25 Nov 2008 15:59 #249327
by RonKZ650
Also did you definately verify you set the cams correct? It's very easy to have the cams off by a tooth. This will not hurt anything, but obviously performance will suffer.
- Nate77
25 Nov 2008 16:25 #249330
by Nate77
1977 KZ650 B1
The cams are set right...
-exhaust "T" arrow lined up with head
-count 36 pins back, beginning with 1st pin ABOVE the exhaust arrow and line up intake cam arrow with the 36th pin, right?
Also, I have electronic ignition.
Bdog Points, coils, electrical? Look at those, the motor would have gone bang or felt real weird if it was inside.
Bdog, what do you mean by "...if it was inside?"
1977 KZ650 B1
