Drag Pipes
- mumbles
- Let's do it...
08 Jan 2009 05:14 #256683
by mumbles
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
Replied by mumbles on topic Drag Pipes
Thanks for posting up the jet sizes. Gives us an idea where to start with similar setups.
What did you use for back-pressure?
2001 KZ1000 Police
1998 Vulcan 800
Houston, Tx
- kzkx
08 Jan 2009 16:27 #256780
by kzkx
81 XS 400 Cafe Project
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
Replied by kzkx on topic Drag Pipes
mitch.dail... It has stock headers. When you cut the stock exhaust you have to be care full if you want to keep the baffles. They are pretty close to the outside edge. I used a sawzall. I started the 2" pipes after the H pipe that goes under the bike. It was right before the stock shield ended so I could cover up the joint.
mumbles... I drilled a hole in the bottom of the exhaust pipe about two inches in on the bottom. Then I welded a washer that was a little smaller diameter to my pipe onto a bolt. Then I bolted it down. I saw this on a guys Harley and he said he can turn it to increase or decrease the back pressure. Sounded good to me.
I can post pics later if wanted...
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
- kzkx
08 Jan 2009 16:36 #256787
by kzkx
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
Oh ya... I was going to mention that I have not checked my plugs yet to see how she is running. I plan to do that Saturday morn. Then I'll see how close I am, but at least I'm closer than I was:cheer:
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
- franknsr
08 Jan 2009 20:40 #256861
by franknsr
Formerly CSRchopper
1991 KZ1000P
Gone but not forgotten
1986 ZG1000
1982 650 CSR -shoulda kept this one-
Lisle Illinois, USA
Replied by franknsr on topic Drag Pipes
kzkx, you running any baffles at all? I ended up putting two sets in my single 2" pipe to keep the sound down to a low roar.
My brother has a sportster with straight pipes and he did the washer trick your talking about. Made just enough back pressure to make the bike run nice.
Formerly CSRchopper
1991 KZ1000P
1986 ZG1000
Lisle Illinois, USA
- kzkx
09 Jan 2009 05:56 #256912
by kzkx
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
Ya I put some 4" baffles and I opened the end up on them. Ya they are kinda loud, but not to the point where they are annoying. The sound is different though.
82 Seca 400
83 KZ 750 LTD
83 KZ 750 Hardtail
98 YZF 600R gone
OKC, OK
