Self porting head?
- iroc355
Self porting head?
17 Nov 2008 08:58
just wondering if anyone has tried doing some mild porting on there head themselves and if so how did it work out? i kno a lot of automotive guys who've done some slight porting on their own heads, just wondering if it is somnething worth trying on the kz's?
its a kz900 head, all original and untouched.
lemme know what your thoughts/experiences are
- BSKZ650
Re: Self porting head?
17 Nov 2008 11:35
in my younger days, I did a lot of gasket matching and cleaning up of ports,, now that I know better, I would rather have it done by someone who has a flow bench that can verify the ports flow evenly, and they can get the most bang for the buck
77 ltd1000, current rider
76 kz900, just waiting
- jordan
17 Nov 2008 13:03
I matched my intake side of the head to the intake boots. I dont know how much of a difference it made or if it is accurate, but it seems to run great.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- guitargeek
17 Nov 2008 16:22
I did some mild porting on my head, mostly cleaning up casting flash and seam lines. I definitely notice a difference!
See here.
See here.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- timebomb33
17 Nov 2008 16:33
i port a lot of heads and i say yes it is definitly worth it.
I THINK MY POWERBAND BROKE
- 77KZ650
17 Nov 2008 17:14
a port match, and mild clean up isnt that bad. clean up the casting flash ect, but dont change the shape any unless you are a pro and know what you are doing. I did a bit of work to my 12 head. used a $20 dremmel knock off:P
07 MDP Rookie of the Year
- PLUMMEN
17 Nov 2008 20:49 - 17 Nov 2008 20:51
now if i was just smart enough to resize a freakin picture!:blush: :laugh:
Last edit: 17 Nov 2008 20:51 by PLUMMEN.
- PLUMMEN
17 Nov 2008 21:59 - 17 Nov 2008 22:03
Last edit: 17 Nov 2008 22:03 by PLUMMEN.
- PLUMMEN
17 Nov 2008 22:05 - 17 Nov 2008 22:06
Last edit: 17 Nov 2008 22:06 by PLUMMEN.
- gane
18 Nov 2008 12:09
Many years ago I was a clubhouse racer,and had the good fortune to meet a Master machinest w/a flow bench. He transformed my 87 hp GS1100 to an 1164 cammed/flowed 132hp. w/33mm smoothbores. years went by and 36mm slingshots added a couple ponys'and made bike smooth and consistant ride. Tom Wirth at Mountain Macine Performance, depending on his mood, is a crochety SOB and by his own account usually over-worked. however, If he takes a gleening to your' project I can think of no better.
[img][/img] 1977 KZ1000A1
- Exitpupil
18 Nov 2008 18:11
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- guitargeek
18 Nov 2008 19:25 - 18 Nov 2008 19:31
If I had loads of extra cash, I'd send my head off to Extrude Hone. Something about the fluid dynamics of of abrasive flow machining really appeals to me, like a Play-Doh Fun Factory. Seems like it takes all the guesswork out of shaping the passages. OE manufacturers are starting to use it on their manifolds where it comes in really handy in polishing those long intake runners.
The media they use is a semi-solid material, impregnated with abrasive particles. Try to hold some in your hand and it'll run through your fingers, but as soon as it hits the floor it becomes rigid. If you pump this stuff through a passage it flows like a liquid but solidifies when it meets an obstruction, which is where the abrasive qualities come into play.
Last edit: 18 Nov 2008 19:31 by guitargeek.
