- Thank you received: 1
now the fun starts...more questions
- quader98
16 Nov 2008 15:07 #247813
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
now the fun starts...more questions was created by quader98
ok.i drained the oil and went to put the plug back in and lo and behold the threads are DONE i used a 17 mm wrench to take out the bolt so i would assume that this was an issue before as i believe the stock one is 12mm. which way should i approach this dilemma
i was inspecting the clutch basket and noticed this,please click on video
82 GPZ 750 R1
- timebomb33
- Thank you received: 10
16 Nov 2008 15:25 #247825
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic now the fun starts...more questions
what the hell happened you act like my ex-wife start something and then walk away.
- PLUMMEN
- Thank you received: 104
16 Nov 2008 16:53 #247838
by PLUMMEN
Replied by PLUMMEN on topic now the fun starts...more questions
are you referring to my several 1000 unfinished projects?:laugh:
- Locozuna
16 Nov 2008 18:25 #247859
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic now the fun starts...more questions
I'll take B Movie Bimbo's for 400 Alex!!
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- Thank you received: 2098
16 Nov 2008 19:13 #247864
by Patton
Replied by Patton on topic now the fun starts...more questions
Hoping somebody takes Unusual Sparkplug Uses.
- timebomb33
16 Nov 2008 20:20 #247872
by timebomb33
b movie bimbos for 400 that is a good price where can i find some for that kind of money.
- steell
17 Nov 2008 05:40 - 17 Nov 2008 05:47 #247895
by steell
Replied by steell on topic now the fun starts...more questions
The play at the clutch basket is the cumulative play between the crank and the clutch basket.
That is the play in the primary chain between the crank and the secondary shaft, and the play between the secondary shaft drive gear and the clutch basket driven gear.
Short version:
Nothing to worry about.
Several methods of repairing your oil drain plug problem, simplest way is to replace the oil pan, harder way is to remove the oil pan and have a new drain made and welded on.
Probably other ways I didn't mention.
By the way, where are the other six replies the board says should be here??? :woohoo: :woohoo: :woohoo: :woohoo: :woohoo:
Short version:
Last edit: 17 Nov 2008 05:47 by steell.
- steell
17 Nov 2008 05:45 - 17 Nov 2008 06:22 #247896
by steell
This is plumb weird!
Just typed an answer to a question in the Engine forum, clicked "Submit" and ended up here in this thread.
Just edited my original post in the other thread asking where the six replies are that the board says have been posted, clicked "Submit" and here I am again!!
It's Official, This board has gone totally wacko!!! (Wacko is a highly technical term, may find it in a Highly Technical Dictionary).
By the way, this thread doesn't exist, so you all can just kiss my big toe!! :evil: :evil: :evil:
Last edit: 17 Nov 2008 06:22 by steell.
- Bluemeanie
- Thank you received: 14
17 Nov 2008 06:02 #247899
by Bluemeanie
Replied by Bluemeanie on topic now the fun starts...more questions
My drain plug stripped out years ago. I removed pan and drilled, tapped for a 14mm oversize plug. Works great. Of course as steell says while pan is off you could also just replace it too. Plenty of them on ebay.
- PLUMMEN
17 Nov 2008 06:05 #247901
by PLUMMEN
put some clutch plates in there!
- quader98
17 Nov 2008 11:19 #247960
by quader98
82 GPZ 750 R1
Replied by quader98 on topic now the fun starts...more questions
lol :laugh: :laugh: :laugh: i was thinking about changing the pan buuut not all 750 pans come with provisions for an oil cooler as you may well know :silly: I've seen other people use the timesert thingy buut that's pricey.they tell you that you need all that stuff to install it but i was looking at the video and all you really need for a stripped drain plug is the insert a drill bit the tap and a new drain plug,why would you need to counterbore it, nothings mating up against it? am i right?
82 GPZ 750 R1
- steell
17 Nov 2008 19:57 #248031
by steell
Hmmm, no more posts, maybe no one can find this thread??
