- Thank you received: 2
oring and base gasket question
- keith1
the four rear studs i replaced, but i m not sure about base gasket.....does it need anything? thanks..
keith......will try to post up pic soon to help
- keith1
i ordered the vesrah top end gasket kit and i dont remember seeing two of them before...they are small rubber orings, one black and one green and are roughly the same diameter of the valve oil seals..no pic as camera was dead again! where do these go? and when i put jugs on , just lay down the base gasket dry?....i know i have to put sealer around
- bountyhunter
- Thank you received: 337
On mine, that sounds like the seals between the crankcase and cylinder where the oil passages go upward.
keith1 wrote:
My base gasket came from the factory with a very strong sealer on it like yamaha 3-bond or similar. I used it when I rebuilt mine since that gasket will never be taken off again for a VERY long time. Don't forget the large O rings that go inside around the bottom of the cylinder tubes.and when i put jugs on , just lay down the base gasket dry?
- keith1
i have the 4 jug orings ( in pic)....so those two small ones go between bottom case and jugs?....thanks
- RonKZ650
- Thank you received: 240
- Old Man Rock
- Thank you received: 225
I've never used the vesrah top end gasket kit but I did have a similar o-ring seal dilema in the upper and lower complete gasket/seal kit I recevied where it turned out to be for the tach...
Just a thought,
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
- keith1
Possibly the tach seals?
Just a thought,
OMR
nope, i m familiar with the tach drive and its orings as mine was shot when i got the bike...thanks though......maybe they go on certain
application and mine doesnt need them....i have to find out though....i only want to do this once..keith
- keith1
Just a thought,
OMR
ya know what...you might be right...i was thinking of the fat one that goes inside...i m gonna go look right now
- keith1
Just a thought,
OMR
yup it looks like the one that goes around the outside of the tach drive...but i dont know why there are two the same,as the other one should be the fat one that goes inside....maybe first day for new guy in packing dept....thanks....
- keith1
- Thank you received: 2098
Here's a page from Z1E.
tach drive o-rings
Good Luck!
