whats the right carb to do the job
17 Feb 2006 16:25 #24564 by oldschool77
whats the right carb to do the job was created by oldschool77
ok he it goes. i got a 1393 big bore kz, 4.29 lift cams dyna 3000 ign port and polished head, new valve job. Pretty much the whole nine yards. im not expecting to street friendly. it drag only. with all that said with would u guys use for carbs. i have and old set of 38mm lectrons but is that gonna do the trick?
  • wireman
  • Visitor
17 Feb 2006 19:36 #24597 by wireman
Replied by wireman on topic whats the right carb to do the job
should be plenty of fuel,im taking the 38s off my 1327 and going with a set of 36s,but its a street bike.:whistle:
18 Feb 2006 06:23 #24641 by oldschool77
Replied by oldschool77 on topic whats the right carb to do the job
whats the advantages to the 36's over the 38's
  • wireman
  • Visitor
18 Feb 2006 10:00 #24672 by wireman
better throttle response on a streetbike,ill run out of @!%^'S before ill run out of carb:whistle: goodluck,happy wtrenching!
18 Feb 2006 21:03 #24813 by 79MKII
Replied by 79MKII on topic whats the right carb to do the job
Is there a really noticeable difference between the 36's and 38's on the street? I have a really nice set of RS38's that I want to put on mine but I'm a little worried about how it will be on the street after reading a few threads here recently. I'll have a 1260 kit, .435 cams, ported/polished head with oversize valves intake and exhaust, msd ignition, etc... What do you think?
From what I have heard, the lectrons are way harder to tune for the street than the flatslide Mikuni's. Have you heard this too?
The Kaw List:
  • wireman
  • Visitor
19 Feb 2006 08:19 #24850 by wireman
i dont think 34s would be quite enough for mine,but 38s are a little sluggish so im going to experiment a little i can allways put them back on later.any ideas?:whistle:
21 Feb 2006 15:31 #25426 by oldschool77
thanks for thae info Wireman!
21 Feb 2006 16:40 #25446 by RomSpaceKnight
Replied by RomSpaceKnight on topic whats the right carb to do the job
With a 1260 kit, .435 cams yada yada I think 38 would be fine for street. Considering the whole bike is barely streetable. That thing must be a handful.
21 Feb 2006 16:41 #25447 by RomSpaceKnight
With a 1393 kit I would expect 38mm lectrons to be the minimum carb for that bike.
