Cam chain wear limit on kz650?
- fmergey
08 Nov 2008 10:33 #246303
by fmergey
Cam chain wear limit on kz650? was created by fmergey
Hello,
I was adjusting my valve clearance and I thought, it would be a good idea to check the wear on the cam chain.
My bike is a KZ650-C3 of 79.
My manuel says "count 20 rivets (the first and the last rivets must be counted) and measure: standard lenght is 160mm, out of tolerance is 162.4mm"
By this, does it actually mean 21 rivets?
Where do I measure? from the center of the 1st rivet to center of the last one? not easy to be accurate!!
If someone knows a different method please help.
Thanks in advance
Fred
Thanks in advance
Fred
- PLUMMEN
- Thank you received: 104
08 Nov 2008 10:42 #246305
by PLUMMEN
Replied by PLUMMEN on topic Cam chain wear limit on kz650?
20 pins center to center
- fmergey
11 Nov 2008 05:07 #246769
by fmergey
Replied by fmergey on topic Cam chain wear limit on kz650?
Measuring center to center 20 pins gives 152mm. What the manual means is, you have to account for pin number 0. Then, the chain is within the tolerance since it is 160mm approximately.
Next time before writing a post with this kind of silly question, I will think twice about it!!
Fred
Fred
