- Thank you received: 1
have questions need answers
- quader98
05 Nov 2008 15:54 #245756
by quader98
Ernie from central jersey
82 GPZ 750 R1
looking to part out my 81 KZ750E2
have questions need answers was created by quader98
hello,my clutch slipped on me over the summer,adjusted it and it worked fine for a little while then it slipped again before i put it away so over the winter i wanna change the clutch out but i don't know which parts to get.do i get the individual plates and springs from z1 or do i get the ape kit from z1 that comes with an extra fiber plate and 1 metal or do i get the barnett kit on ebay that comes with everything...please help
82 GPZ 750 R1
- guitargeek
- Thank you received: 50
05 Nov 2008 17:40 #245764
by guitargeek
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
Replied by guitargeek on topic have questions need answers
Do you race your bike? If not, I'd say just get the plates. Use sandpaper to break the glaze on the steel plates. I did this, didn't replace my springs, and my clutch hasn't slipped once since then, even after the rebuild with the ported head.
- bill_wilcox100
05 Nov 2008 17:42 #245765
by bill_wilcox100
1977 KZ650-B1 (Stock)
Upgrades:
- Dyna S Electronic Ignition (DS2-2)
- Dyna 3 Ohm Coils (DC1-1)
- Coil Repowering Mod
- Progressive Springs Front & Rear
- Saddlemen Seat Cover
- New Metallic Red Re-Paint & Repro Badges.
Montreal, Canada
Replied by bill_wilcox100 on topic have questions need answers
When I changed mine, 3 years ago, I changed all the plates and got new springs. Still working great today.
Remember, don't use any Low Friction engine oils or Low Friction additives or you will have slippage on your new plates.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
- timebomb33
- Thank you received: 10
05 Nov 2008 19:58 #245798
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic have questions need answers
if you have accsess to a bead blaster blast your steel plates as long as they are not warped when you blast them it give a bit more surface area for the oil to adhere to if your fiber plates measure in spec. and they have no pieces missing and look alright you should be able to keep using them. the stock springs should be good if they measure in spec and are square.i use used plates in my dragbikes and hillcimber and the only time i've ever burnt a clutch was because of improper adjustment or thru a bad experiment with oil brands and type. if i hurt a clutch it's because i've broken plates.
- bountyhunter
- Thank you received: 337
05 Nov 2008 22:51 #245814
by bountyhunter
Replied by bountyhunter on topic have questions need answers
Springs are cheap, put in new ones if you do a clutch job. The springs on mine went south at about 50k miles.
- Old Man Rock
- Thank you received: 225
06 Nov 2008 02:03 #245824
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic have questions need answers
Can't go wrong with the Barnett kit... As you wrote includes everything you need including springs!
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- BSKZ650
- Thank you received: 14
06 Nov 2008 05:16 #245833
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic have questions need answers
The Barrnett is a good clutch, stiff as hell, and when you release it you damn well better be ready to go, no slip or half clutch .
my two cents, the stock is just fine for street riding
- wiredgeorge
06 Nov 2008 07:32 #245847
by wiredgeorge
Replied by wiredgeorge on topic have questions need answers
Weak springs will allow plates to slip BUT if you get new springs, even standard springs are stiffer then the original OEM springs in most cases. Never buy HEAVY DUTY springs as these will give your clutch a super-heavy feel.
- Locozuna
06 Nov 2008 11:14 #245881
by Locozuna
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
Replied by Locozuna on topic have questions need answers
Nope.. I'm with WG. Heavy duty springs are not needed. (Maybe a track bike) Don't throw away your old springs. You might want them back. I often think of putting a hydraulic on them. Hands ain't what they used to be but neither is $$$$....
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
- quader98
06 Nov 2008 13:29 #245910
by quader98
82 GPZ 750 R1
Replied by quader98 on topic have questions need answers
ok,i'll stay away from the hd kits,I'm not looking to race or anything like that.does the barnett kit have hd springs?it doesn't say it in the listing.i don't want to use the old parts cause with my luck I'll miss something or miss read something and have to do it over :huh: ...know what i mean.should i also get one of these
www.z1enterprises.com/detail.aspx?ID=257
thanks for the help
thanks for the help
82 GPZ 750 R1
- bill_wilcox100
06 Nov 2008 14:58 - 06 Nov 2008 15:08 #245916
by bill_wilcox100
Upgrades:
Montreal, Canada
quader98, I installed that same Roller Clutch Push Rod Kit from Z1 last winter.
By the time I rode the bike this spring I had long forgotten the original feel.
Certainly didn't make anything worse or quirky.
Best of success.
Best of success.
Upgrades:
Montreal, Canada
Last edit: 06 Nov 2008 15:08 by bill_wilcox100.
- Old Man Rock
06 Nov 2008 15:45 #245924
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
