- Thank you received: 6
weird noise out of clutch cover ( with video )
- kawsakiman
05 Nov 2008 10:58 - 05 Nov 2008 10:59 #245720
by kawsakiman
weird noise out of clutch cover ( with video ) was created by kawsakiman
i went for a short ride today on the parkway (about 50 miles) and heard this noise when i got off the parkway.
i was not really into it at all. mostly 65-70 mph @ 4,000 -5,000 rpm's.
now this is a new noise to me. it sounds like something is loose in there. goes away under slight load.
think the basket springs let go and are rattling?
about the last thing i need is to tear apart another motor right now.
Last edit: 05 Nov 2008 10:59 by kawsakiman.
- MFolks
- Thank you received: 540
05 Nov 2008 11:10 #245721
by MFolks
Replied by MFolks on topic weird noise out of clutch cover ( with video )
Get a new gasket,lean the bike on the side stand,and remove the cover. It sound like loose clutch springs or the clutch basket. Not too hard of a fix as parts are still available.
- timebomb33
- Thank you received: 10
05 Nov 2008 21:35 #245810
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic weird noise out of clutch cover ( with video )
it also could be because of the nut holding the clutch basket in place on the input shaft has backed off. tear the clutch cover off and have a look put the bikeon the side stand and you won't even leak oil.
