Conversion to propane?
  • Bicycle Lee
  • Bicycle Lee's Avatar Topic Author
04 Nov 2008 09:14
#245519
I was just wondering if anyone had ever seen this done to a KZ or any other bike for that matter?
1978 KZ1000 police
  • BSKZ650
  • BSKZ650's Avatar
Re: Conversion to propane?
04 Nov 2008 09:22
#245522
where are you going to carry the tank?
77 ltd1000, current rider
76 kz900, just waiting
  • MFolks
  • MFolks's Avatar
04 Nov 2008 09:36
#245524
Almost anything is possible given the time and money. A propane conversion will need the tank,pressure regulator,and modified carbs to function. I'm not sure of the energy difference between gasoline and propane and your need to fill up versus going to the gas pump.
  • PLUMMEN
  • PLUMMEN's Avatar
04 Nov 2008 10:49
#245543
i think there is a name for a bike hauling around a propane tank,its called a kamikazee!:laugh:
  • wiredgeorge
  • wiredgeorge's Avatar
04 Nov 2008 12:27
#245562
You sit there with four gallons of gasoline between your legs over a hot engine and hot coils connected to a battery and complain about propane? Bwhwhwhwa... Hey, how about methane? I got this idea that involves Mexican food, a hose... ah never mind.
As far as propane goes, can't you look up public busses or school busses that use it?
  • 77_650B1
  • 77_650B1's Avatar
04 Nov 2008 12:35
#245564
Propane would require fuel injection, and to find LNG or CNG (liquid or compressed natural gas) injectors that you can fit into your TB's. Other than that, a prop tank and a reg is the only difference from running a regular fuel injected bike, except you dont need a fuel pump and tuning might be a bit tricky.
Check back with me next summer, me and a friend may be trying to convert my CB400 to run on hydrogen over the winter as part of our final project in our engineering degree. We'll be using direct injection, should be fun. If I make her run on hydrogen, I'll be riding her every day, for the cost of water and a little electricity. We plan on developing a household H2 filling station as well, so you can fill a motorcycle or small car overnight.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • ronjones
  • ronjones's Avatar
04 Nov 2008 17:01
#245599
77_650B1 wrote:
... me and a friend may be trying to convert my CB400 to run on hydrogen over the winter as part of our final project in our engineering degree. We'll be using direct injection, should be fun. If I make her run on hydrogen, I'll be riding her every day, for the cost of water and a little electricity. We plan on developing a household H2 filling station as well, so you can fill a motorcycle or small car overnight.
Did you see the mythbusters where they just directed a jet of H2 into a standard carb car, and it ran...until it backfired and caught on fire:laugh:
  • 77_650B1
  • 77_650B1's Avatar
04 Nov 2008 17:12
#245601
That was hilarious. I think that actual injectors may be your best bet on that one. :laugh:
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
  • PLUMMEN
  • PLUMMEN's Avatar
04 Nov 2008 19:45
#245642
knock the top off a propane tank and see what happens!:laugh:
  • hardr0ck68
  • hardr0ck68's Avatar
  • Who put the what in the where?
04 Nov 2008 20:08
#245643
Every cab in South Korea is now propane, many of the delivery trucks are as well. It's a very clever way to keep the prices of each energy source in check.
You can fill up with gasoline, Propane, or Diesel most everywhere. When gasoline was going crazy many folks just had their cars converted to propane, takes about 2 days turn around and the fuel was alot cheaper....
I think that if you are in a crash that ruptures your fuel tank you are in for a world of hurt no matter what fuel you use....
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
  • APE Jay
  • APE Jay's Avatar
05 Nov 2008 09:13
#245701
You should contact Hank Hill. He is the expert in propane and propane accessories.
  • JMKZHI
  • JMKZHI's Avatar
Re: .
05 Nov 2008 12:18 - 04 Dec 2008 09:41
#245729
del
Last edit: 04 Dec 2008 09:41 by JMKZHI.
