- Thank you received: 9
replacement pistons
- Bdog
- Sweep the leg johnny!!!
02 Nov 2008 13:40 #245188
by Bdog
kzrider.com/forum/11-projects/338400-a-little-bit-of-an-upgrade
'77 KZ650-C1 -- build
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
ContiMotion tires (120/60-17&170/60-17)
replacement pistons was created by Bdog
Is there any way to get a replacement piston from Wiseco for an 810 kit. I opened the motor and the dome is all pitted, I would guess from detonation, but only one piston. Does that sound right?
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- steell
02 Nov 2008 16:11 #245223
by steell
Replied by steell on topic replacement pistons
I believe Wiseco sell all the parts individually, pistons, rings, pins, even circlips.
Call them.
Call them.
- timebomb33
- Thank you received: 10
02 Nov 2008 16:16 - 02 Nov 2008 16:18 #245224
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic replacement pistons
the wiseco part no. for that piston is 4186ps,the rings are 2717xc, the headgasket is w3163 hope that helps. thier main phone number is 1-800-321-1364
Last edit: 02 Nov 2008 16:18 by timebomb33.
- bountyhunter
- Thank you received: 337
02 Nov 2008 18:01 #245236
by bountyhunter
Replied by bountyhunter on topic replacement pistons
For the record: would some pitting hurt anything? The new pistons I installed were very rough finish on the top, I remember sanding them smooth (er) for fun and looks. Would it make any difference if the top had pits on it?
- PLUMMEN
- Thank you received: 104
02 Nov 2008 18:50 #245248
by PLUMMEN
Replied by PLUMMEN on topic replacement pistons
are they pits or dings from something going bump,what do the valves and chamber look like?
- mark1122
- Keep twisting it
- Thank you received: 109
03 Nov 2008 09:29 #245357
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic replacement pistons
The pitting should not hurt. They will end up covered with carbon anyways.This is just on top right?
It would be good to try and find out what caused the pitting.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 77_650B1
03 Nov 2008 09:32 #245358
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Replied by 77_650B1 on topic replacement pistons
If the valves and stuff dont look bad, then I'd try goin up a size or two on your carb jets, sounds liek a lean condition. Or another thing, are you using supreme gas? Should switch to supreme after going up in compression ratio.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- wiredgeorge
03 Nov 2008 10:50 #245369
by wiredgeorge
Replied by wiredgeorge on topic replacement pistons
If the pitting is occuring on only one piston crown, is the jetting too lean on only the one cylinder? If the octane in the gas he is using is too low, wouldn't there be pitting on the other piston crowns as well?
I would have to look at what you are calling pitting. If it is indeed pitting from a lean conditioin, I would expect the carb holder to be the culprit... allowing air to hit the piston crown and focus heat in that location.
- 77_650B1
03 Nov 2008 11:05 #245372
by 77_650B1
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
Thats right, I wasn't thinking George. You're right, somethings causing a lean condition in just that one cylinder.
1977 KZ650-B1
-Dual Discs
-Dyna-S
-WG Coil Mod
-Alloy Wheels
- Bdog
03 Nov 2008 18:03 #245424
by Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
Replied by Bdog on topic replacement pistons
Thanks for all the ideas, here is what I know of the engine. Used and it had an 810 kit in it and new dyna coils and dyna s ignition plate for $220. I would like to get a picture up of the piston. Gonna take it to shop that I trust tomorrow. The new pistons are $135 a piece with rings and that ain't bad for what I have in the motor. The carbs that I got were kinda sh%&*y looking Mikuni CVS like the the ones on GPzs. BS34 I think. The cylinders don't look bad but I will prolly get them honed and pretty, or is that a bad Idea. The head was ported all to hell and It is a shame because Its the 650 head with the cool cam cover adn smaller compression chambers. The idea is to use this top end on my 750 bottom end that was good other than leaky base adn head gaskets and was dying for a big bore. Also picked up some jetted Gpz750 carbs (the black ones) and the kz750 motor already had gpz cams in it so it oughta really fly now. any tips or tricks for fitting these pistons would be great, taking them out of the old motor was kind of a pita.
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
- timebomb33
06 Nov 2008 22:37 #246023
by timebomb33
if your putting fresh rings in it id hit it with a ball hone just to knock the glaze of the cylinder.
- Bdog
07 Nov 2008 04:03 #246038
by Bdog
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
I was only planning on replacing the fouled piston and rings. Not all four sets of rings. Is that unwise, and why? I was just gonna hone the one cylinder and everything else should be like changing a base gsket, yes? There was very little use of the pistons, very little carbon on the domes, and it just wiped off. Please correct me if this sounds crazy. I don't have a boat load of money to throw at this motor, and the new piston is money allocated for other aspects of the project. thanks
810 kit
GPZ cams and carbs
ZX6R front end
GSXR600 Rear
Kerker
Dyna
Accel
