- Thank you received: 225
Thank you Lord for stud removers!
- Old Man Rock
30 Oct 2008 12:27 #244676
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Thank you Lord for stud removers!
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
30 Oct 2008 14:44 #244691
by keith1
Replied by keith1 on topic Thank you Lord for stud removers!
so apparently this is one of the fun things to expect soon on my freshening up session ? i think i m leaning towards pipe wrench and bernzomatic......
- Jeff.Saunders
30 Oct 2008 18:34 - 30 Oct 2008 18:38 #244730
by Jeff.Saunders
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Replied by Jeff.Saunders on topic Thank you Lord for stud removers!
I've tried a number of different ones. I have the one APE sells, I have a Craftsman one, I have a couple of other ones too - but the only one that works properly is the Snap-On version.
Snap-On part is A50 or A50A - you can get the tool with two different racks - both are useful... Not cheap new, but often they come up on ebay for $30-$40.
It's not about money with this tool - many of the cheaper ones fail totally to bite into the studs and just slide around the stud.
Z1 Ent on Facebook,
Last edit: 30 Oct 2008 18:38 by Jeff.Saunders.
- Jeff.Saunders
30 Oct 2008 18:37 - 30 Oct 2008 18:40 #244733
by Jeff.Saunders
Z1 Ent on Facebook,
There's one on ebay at the moment...
motors.shop.ebay.com/merchant/flowers-n-things
Z1 Ent on Facebook,
Last edit: 30 Oct 2008 18:40 by Jeff.Saunders.
- timebomb33
- Thank you received: 10
30 Oct 2008 19:10 #244743
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Thank you Lord for stud removers!
o.t.c makes a set of individual stud pullers they are a socket with a sprag in side that grips the body of the stud not the threads and they won't scar the stud body up so that you can reuse them if need be, they come in 6mm,8mm,10mm, and 12mm sizes the really nice feature about them is that it is a socket so you are not limited space wise like some of those gear type pullers . i have a standard set as well for all those h.d's i have to work on from time to time. they also can be used as an installer as well.
- H2RICK
- Is this a fun bike, or what!!!
30 Oct 2008 20:12 #244761
by H2RICK
I have used a pipe wrench in the past because I was worried about wrecking the MP removers. I use the MP removers only on smaller studs....especially ones in hard to get at places.
KZ650C2 Stock/mint. Goes by "Ace".
H2A Built from a genuine basket case. Yes,it's a hot rod.
GT550A Stock/mint. Pleasant stroker.
2006 Bandit 1200S for easy LD rapid transit
Various H2 projects in the wings.
Replied by H2RICK on topic Thank you Lord for stud removers!
Yep, Motion Pro makes the same stuff....maybe they come from the same factory. MP also makes the stud installers that fit on the threaded end. I have both sets of these nifty little tools.o.t.c makes a set of individual stud pullers they are a socket with a sprag in side that grips the body of the stud not the threads
- kawsakiman
- Thank you received: 6
30 Oct 2008 20:14 #244762
by kawsakiman
Replied by kawsakiman on topic Thank you Lord for stud removers!
i bought mine from mac tools years ago.
it's just one of them tools you only use once in a great while but are gratefull you own when you need it.
i don't care if mine galls the studs, i throw them out any way.
i have another version i'll snap a picture of when i get to work.
that set works great for the smaller studs like exhaust studs.
- Tony
- Thank you received: 13
31 Oct 2008 20:06 - 31 Oct 2008 20:07 #244882
by Tony
Replied by Tony on topic Thank you Lord for stud removers!
When I did mine this summer I needed two vise grips. One simply wouldn't do it. Then, it was about a 1/4 of a turn at a time for just about every one of them. Very time consuming. i couldn't find my pipe wrenches that day.
Last edit: 31 Oct 2008 20:07 by Tony.
