- Thank you received: 2
10.5 to 1 1075 rebuild
- keith1
i am going to tear apart bike this weekend and hopefully get the pistons and jug installed...i bought ape heavy duty studs and a pin removal tool...
any tips?...my only worries are concerning cam chain..i just dont want to screw it up as far as it dropping when i install other parts...i think i will be going it alone for this phase..no second set of hands...bike has 30k on it and i am wondering if a stock cam chain can take the stress
of heavy duty srings and ape 410 cams when i have the head redone down the road..just kind of thinking out loud.....how much would i expect to pay for some mild head porting?...i would like to get the most of my time and money....thanks in advance for any and all replies.....keith
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- keith1
as far as tearing it down all the way, i m not sure its within my realm and its just gonna be a street bike with the occasional blast....i m not the dump the clutch at 6k at 60 mph wheelie kind of guy.....keith
- freebyrd24
- Thank you received: 4
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- keith1
- RonKZ650
- Thank you received: 240
- timebomb33
- keith1
- keith1
cometic makes them so does vesrah and athena any i've missed guys. you should be able to get them from parts unlimited,z1 enterprises and ape as well any number of places, as far as tearing down the motor you are already doing the hard part by taking off the head and barrel the rest will be alot easier, you will be happy if you do it .just follow your manual step by step and you should have no trouble. it is well worth the extra effort. have i lied to you yet.
nope, cant say you have!!!!....its just this is the first time i have delved into motor work...i have learned a lot so far from the manual and the help here.....guess i ll be asking a lot more questions....thanks man!!!....this should be an adventure........keith
- Thank you received: 797
no need to be worried about splitin the cases it sounds much worse than it really is,nothing jumps out at you nothing tricky to re-set or anything.as timebomb33 stated getting the head off is the hard part,and thats not hard.yes a "new" stock cam chain will hold up to your 1075 just fine.a used one "might"but then you are gambling your parts and labor.on top of all that nothing can compare to being able to go through your engine in your head while you are trying to go to sleep,instead of counting sheep :laugh: .
besides you have all of us "know it all smarta$$es" to fall back on if you get stumped:P .
- trippivot
- Thank you received: 3
13-1 is a different story bud. pinging knocking banging actually sounds like a hammer inside the engine
do not forget air cooled engines have an operating temperature that will get to 350 F head temperatures and operate just fine.. if the engine burns your skin that is correct.
as for a camchain...
if you are doing redline clutch drops get a new one
if you ride smooth and like roll on the power leave it alone and just do the top end.
when it is time to street cut 2 and 3 gear do it then...
- trippivot
cometic gaskets good
vesrah gaskets good
web cams good
camchain - tsubaki--best!!
get 34mm CV carbs A+ good and smooth best for the money!!
vance and hines -good
more power will have you thinking about fork springs and brakes soon.
