- Thank you received: 80
oil in exhaust pipes-rings
- CoreyClough
- GPz550 Addiction
Hand hone the cylinders, send the head out for rebuilding, and install a fresh set of piston rings, after cleaning up the pistons, and you'll be set.
'85 GPz550(ZX550-A2)
- bountyhunter
- Thank you received: 337
13008-059 Standard Piston Ring Set for a 1977-1983 Kawasaki 650SR. Kawasaki lists your piston rings as "Active" which means they are still available from any Kawasaki Dealership. Currently in stock in all 3 Kawasaki US Warehouses even with an order of 9.
I would check cylinder wall wear and see: if more than a couple of thou, you may want to put in the next size larger rings (and shave the ends to get proper gap). If you are only honing the walls, the larger rings will cut into them and seal over time. Anyway, we used to do that to get another 40k miles out of a car engine. They won't be sealing real well at start up, you will have to break them in. It's a lot cheaper than a bore job with new pistons and rings. Not as good, but will give you some good service.
- bountyhunter
I wouldn't be surprised if the dealer price was in the $50/set ballpark or higher. You can save money on OEM parts ordering them from Babbittsonline.com. They usually give about a 20 - 30% discount off the dealer list price for parts.13008-059 Standard Piston Ring Set for a 1977-1983 Kawasaki 650SR. Kawasaki lists your piston rings as "Active" which means they are still available from any Kawasaki Dealership. Currently in stock in all 3 Kawasaki US Warehouses even with an order of 9.
13008-059
KZ650-E1 LTD (1980)
Assembly: CYLINDER/PISTONS
RING SET,PISTON,STD (SKU: 13008-059) $47.94
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
- TODDSTER
- Die Hard & Live Free
How do ya hand hone the cylinders? Is that fancy talk for finely polished-taking out the wall scratches in the cylinders?
Good idear on next size rings if cylinder wall size will allow me to do that. I'd like to stay as close to stock if I can. My baby will be more of a classic if I can do that. Thinking about classic plates on my 78 650 sr.:lol:
Good price on the ring sets at babbits bounty hunter. I'll definatly(spelling) check it out.
Well I'm going to change the oil & filter & run her til the weather keeps me out of the saddle & makes me take her to the shed for a make-over, along with some choice words, bruised knuckles,& thoughs of spring time rides.:woohoo: Thanks for the pointers & sage advice. Later....krazy kawi dudes!!:silly: Honorable mention to Corey Clough & Bounty Hunter;)
KZ 78 650 SR D1a W/78 Quick silver 3/4 stock fairing, new dunlop rubber frnt. & back, new jcw rear shocks, new progressive frt. fork springs & 1 ground-hog to my credit.(ouch)
TODDSTER in N.Western PA
Kawi Strong w/windshield in my face
- bountyhunter
It's a tool attached to a hand drill like this:How do ya hand hone the cylinders? Is that fancy talk for finely polished-taking out the wall scratches in the cylinders?
www.mytoolstore.com/kd/kdengi10.html
- TODDSTER
- bountyhunter
- TODDSTER
- bountyhunter
Bounty hunter-How do you know when you have honed the cyl enough to have cut through the glaze & still keep it to within tolerence to use upsized (next size)rings.Did i state this question right? Do you get what I mean? How do you go about honing ,deglazing to clean up cyl for rings etc.? And is it something some one can do if they've never done this sort of thing before?
You will know when the cylinder walls have been honed enough because the shiny smooth face will be gone and you will have the cross hatched surface with fine lines. You want to cut the absolute minimum material away while doing this to keep the piston fit as tight as possible.
It's been a while since I did it, but the goal is to get angle cross hatching by moving the drill up and down to make diagonal lines on the walls. Anyplace you see a shiny glazed surface means it is not honed yet.
After you are happy with th cylinders, you set the rings in and measure the end gap with a feeler gauge. Cheack against manual spec, typically you want to have about .003" PER INCH OF PISTON DIAMETER. If needed, you can carefully file the ends of the rings (don't chip them).
Before choosing between stock rings and the .010" over ring size, hone the cylinder and measure the diameter afterwards. If the diameter is closer to stock, the stock rings would work better. If the wear is .004 - .005" or more, probably best to go to the .010" over rings and shave the ends.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- bountyhunter
Good point. If the cylinder walls have some wear, flat rectangular hones won't be able to get the whole cylinder wall surface and may leave the low areas untouched.you are better off using a ball hone
- TODDSTER
