how to raise max RPM's
- roy-b-boy-b
Re: how to raise max RPM's
26 Sep 2009 03:30
I was getting into Ford 302 engines a while back and i was looking at all the radical things i could to run against 350 chevys.
351 winsor ctank,etc,etc, Boy i was going to build a 302 out of this world.
And then one day it hit me. I had a 351 winsor and it only needed to be removed and installed and cammed up a little and i have saved $3000.00.
Thes bike are what they are and you can do anything you want with them but as the questions asked,"Is it still a 650".
I remember when the 650 was taken to the firestone proving ground a long time ago and run for 24 hours. They broke over 120 records. Was stated it could never happen again.
As the stated limiting factor for the higher RPM is the two valve head you are going to have to get a better head.:laugh:
Or, You could buy a bike that will turn the big rpms and wonder what the benifits would be to own a bike that would pull from 3500 rpm to 5000 and not have to shift.
- will61310
26 Sep 2009 03:46
hardr0ck68 wrote:
Im pretty Sure the zx6 doesnt redline till over 12 or 13,000.. just buy one of them and keep your 650 reliable, then you can have both..:lol: Well then how about 12,000
I understand that the work to get a motor to turn like that won't be cheap...
Why is higher compression on the list? Wouldn't more squish slow the motor sown?
Do you think a motor with this work could be a street bike and reliable while still shifting at 11g?
...1980 LTD 1000...
- hardr0ck68
- Who put the what in the where?
26 Sep 2009 06:52
If I wanted to buy a zx6, or an R6 or a cbr600 I would own one now...and be blissfully ignorant about what it takes to make an engine work and work well.
You folks never get on a gpz1100 guys telling them to just buy a busa, or zx1400 and not bother with adding a turbo or NOS.
Yeah it will be questionable if it will still be a kz650, but it will be MY bike.
I really miss Steell cause that guy knew stuff other than "buy a new bike"
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- TerryK
26 Sep 2009 07:12
I think you need to keep it all in perspective. These motors are ancient technology and were never designed to turn the kind of rpms you desire. Sure it's fun to kick around the idea of a 13,000 rpm KZ650 surprising modern sportbike guys at a stoplight, but like others have said, unless you are willing to spend an outrageous amount of cubic dollars on a hard to ride, unreliable hand grenade then you should probably stick to more conventional mods and rpm limits.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- hardr0ck68
26 Sep 2009 07:28
Well I am planning on 810, head work, crank work, built con-rods, FI, and heavy cams.... but then how do you know the "red line"
as for surprising the sport bike guys, I know I will never touch my buddies warmed up r6....not with out a budget of $100,000. I am cool with that. All I want is to build my bike.
I am asking these questions because talk is free and information should be bounced around these forums... but if the best info to be had is; "it's expensive, not common, not worth it..." well then it might be time to stop asking questions on this forum.
As for unrideable.... I am smart enough to keep everything working together. The goal is a nice smooth torque curve on the dyno.
1977 kz650 c1
- TerryK
26 Sep 2009 07:34
hardr0ck68 wrote:
It seems like you know what you want to accomplish with the your budget, and that's cool. Keep us posted on your progress!
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- larrycavan
26 Sep 2009 08:01 - 26 Sep 2009 08:09
hardr0ck68 wrote:
Geesh....that's reasonable enough. Find a 750 head to start with. They're 10CFM @10" over a stock 650 head before you touch the ports. 69 vs 59. They'll go low 80s with stock valves and runner size doesn't have to be over done. That will meet piston demand for a very high VE number. Much better ports IMO than the KZ900/1000 heads were from the factory.
Web 110 Grind cams will make upper RPM Power.
Web 118 Grind would better suit all around street behavior.
Even the 118 grind with 34mm stock 750 intake valves meets curtain area requirements.
110 has a quicker ramp speed
I'd put new aftermarket buckets in it as well.
29mm CRS Keihins to feed it. Those carburetors rock.
FI is cool but you better have a good map to start with on a fresh built high performance motor or you're rolling the dice in a very risky game
Obviously a good pipe to top it off.
Last edit: 26 Sep 2009 08:09 by larrycavan.
26 Sep 2009 08:21
hardr0ck68 wrote “I have read that some folks say higher RPM's are not what it takes to make power... I have always been under the impression though that with these inline 4's higher rev's is the way to go.â€
Higher revs on a stock KZ650 is not the way to make power. According to the Kawasaki Factory Service Manual horsepower begins to drop after 8,000 RPM and torque starts to drop after 7,000 RPM. If one of these engines was running at 11 – 13,000 RPM (without blowing up) it wouldn’t make any more power than if it was running at 5,000 RPM. Perhaps if a bunch of modifications were made, such as larger displacement, different heads, turbo, fuel injection, NOS, different crank, different rods, etc., higher revs might contribute to additional power, but that wasn’t the original topic. Ed
- PLUMMEN
26 Sep 2009 08:53
think of how much faster you wear out parts at 8,000 rpms versus 6,000 rpms,now try to imagine 13000rpms.i dont imagine youll find many of the new sportbikes running origional motors at 30,000 plus miles 30 years from now that can still carry themselves down the road :laugh:
- will61310
26 Sep 2009 09:22 - 26 Sep 2009 09:24
hardr0ck68 wrote:
I havent seen anyone else wanting a 30+ year old engine to rev up to 13-15,000 rpms either..so buy a zx6, put the engine in your kz650, and spin your heart out...problem solved :laugh:If I wanted to buy a zx6, or an R6 or a cbr600 I would own one now...and be blissfully ignorant about what it takes to make an engine work and work well.
...1980 LTD 1000...
Last edit: 26 Sep 2009 09:24 by will61310.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
26 Sep 2009 13:46
You will know the redline one of three ways,
1) When quits pulling miles per hour.
2) You put it on a dyno and see when it quits making horsepower or torque. It depends on what you are building for. Over reving it, will be a waste of time.
3) You over rev it and it blows up.
You talked about a smooth torque curve on the dyno. You did not state the rpm range, that you wanted the torque in?
I did not know what to think, after reading your opening statement:
"I am asking these questions because talk is free and information should be bounced around these forums... but if the best info to be had is; "it's expensive, not common, not worth it..." well then it might be time to stop asking questions on this forum".
NOTE- If you are looking for a special, one of, engineering project, this might not be the site for you. If you are looking for a performance or racing build, we can help with that. Information or ideas are free here, disrespect or wasting other peoples time, is not free.
We want to help, will you allow us to help you, is the question?
- hardr0ck68
26 Sep 2009 14:15
No I am totally in for advice, and I do listen...
It is just frustrating seeing all the comments along the lines of "if you want to o that fast, buy something else"
We are all here because we are into these old bikes, I don't want to play with a new bike, I like playing with mine.
I know that on the stock motor more rev's will not help. My goal is 100hp on a dyno with a smooth torque curve...so I think I will need to get a bit exotic. If someone has built a 100 kz650 before then awesome, just let me follow that pattern. I know that Dave Slone got about 85hp on a dyno with a 810 kit and FI. So I am going to need more than that.
I know for sure I am not the only one who wants to build a 650/750 block. Dave did it, Steell was all about the small bikes, Mark Wing has a hot 650.... so should they have all just bought zx6's?
1977 kz650 c1
