how to raise max RPM's
Re: how to raise max RPM's
09 Oct 2009 13:40
hardr0ck68 wrote: "In his post he stated a "safe" piston speed of 4500fps..."
OK, it’s back to arithmetic class for you guys.
Let’s multiply 2.13 INCHES times 11,000 Revolutions per MINUTE:
I get 23,430 INCHES per MINUTE.
Let’s divide 23,430 INCHES per MINUTE by 12 to get FEET per MINUTE:
I get 1,952.5 FEET per MINUTE.
Let’s divide 1,952.5 FEET per MINUTE by 60 to get FEET per SECOND:
I get 32.5 FEET per SECOND (fps).
However, remember in one revolution the piston makes a trip up and down the cylinder, so we need to multiply 32.5 times 2 to account for the round trip per revolution. I then get:
65 fps.
I won’t show the math, but 65 fps = 44.3 mph
4500 fps = a whopping 3068 mph; literally “faster than a speeding bulletâ€
65 fps.
- hardr0ck68
- Who put the what in the where?
09 Oct 2009 20:48
will61310 wrote:
just in that i would imagine a stroked modern liter bike would very close to the same stroke as the 650. So unless physics has changed in the last 30 years or busa's use parts from metal that cannot be found from wiseco or atp then I don't see why the two cannot run similar piston speeds.
I just checked, a busa runs a stroke of 63mm and falicon offers an 11mm stroker crank for a total stroke of 74mm. Man they must have to shift at 5g to keep that thing from coming apart :blink: :laugh:
So how is it a busa can run higher piston speeds? depleted uranium con rod bolts? Ti pistons?
are you telling me all the stroker 'busa shift at 8,500?
Now you're just being stupid, comparing a kz650 to a busa??:dry:
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- hardr0ck68
09 Oct 2009 20:59
650ed wrote:
my bad, leave it to me to screw up a plug and play formula... however i used the formula beatpoet gave correctly i believe just used fps not fpm as he had listed. Again his post claims a "safe" limit of 4,500 fpM
65 fps.
1977 kz650 c1
- larrycavan
10 Oct 2009 06:14
Timbomb already showed you an example that came apart at less piston speed than that....
- trianglelaguna
10 Oct 2009 06:23
paper mache pistons are able to spin faster...also.....using wd-40 instead of that heavy old engine oil...plus never forget ...wheight equals power loss.....train a monkey to pull the trigger
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- will61310
10 Oct 2009 06:43
This guy is like a little kid...You know,when you tell them NO, but they keep asking and asking and asking,trying to get you to say yes. I consider Larry C. to be somewhat of an EXPERT on these engines,and if HE doesnt think it possible, then apparently it cant be done.. Anybody know what rpm's Lorcan is shifting at? Im quite sure he has done Vast research,and spent more time and money than this guy is ever gonna put into his...
...1980 LTD 1000...
- trianglelaguna
10 Oct 2009 07:01
(youtube)
this surfer knows about rpm's
1976 KZ900
2003 ZX12R
2007 FZ1000
2003 ZX12R
2007 FZ1000
- larrycavan
11 Oct 2009 04:51
hardr0ck68 wrote:
Exactly what is it you want out of the engine? At first the thread appeared to be about you wanting to spin it at high RPM.
It's getting into a "practical vs possible" debate without any clear objective to be achieved.
Outside of people saying forget it, you've stood solid with determination of achieving something....I don't think anyone knows what that is though.
If you laid out some specific, clearly defined objective, then people could & would [I think] help you.
As it is, you're just aimlessly pissing in the wind....
You have to generate enthusiasm about a project if you intend to receive help. Then when it's offered to you it's rather customary to show a little gratitude now and then. I don't see a single "thanks guys" anywhere....
People's time and experience may be given freely but there are limits to how much anyone will help if they get frustrated form lack of direction and/or appreciation.
JMO...but I do believe it's time to step up to the plate and swing the bat at the ball rather than sitting on the bench telling everyone that hitting a home run with a baseball bat and a football is possible.....especially when they've been playing with a hardball for a long time...
So there it is kid....it's your play
will61310 wrote:The most knowledgeable people on this site tell you what to do in order to make power with a 650 many different ways,yet even though they tell you the rpm limits, you seem like you will argue your point till you get the answer you WANT to hear..Wow, i cant believe this is still going on...
No, I will keep asking questions and getting information until i think I know the limits and how to push them....
- will61310
11 Oct 2009 05:43 - 11 Oct 2009 05:55
After all is said and done - he's building a 750..
...1980 LTD 1000...
Last edit: 11 Oct 2009 05:55 by will61310.
- hardr0ck68
11 Oct 2009 08:16
I am sorry if it seems I am ungrateful.
I am honestly thankful for all the good information given in this thread. It just seemed to me that raising the rev limits is a way of increasing power that is little thought about.
I was just looking to pick more knowledgeable peoples brains.
I am not really appreciative of people saying don't do it, or buy a new bike, because those posts are non-productive.
The thread was started so I could learn what are the reasons the rev limit is 9,000 and what limited it to that level.
Valve float was not mentioned and I was surprised but piston speed and rod stretch were.
Then I was informed that these motors could not make power there, for design reasons however I still don't understand that so well. I believe someone mentioned that the 2 valve head cannot flow enough, and when made to it becomes a very peaky/ hard to ride engine.
My personal goal, which is different from the discussion in the thread (because I am trying to look at many different power adders) is to build is a streetable (and still easy/fun to ride) 100hp kz650. It will not be 650cc's by the time its done, and it may or may not go turbo. I have no problem taking years to collect the parts and put it together right. Also if it red-lines at 9g I am alright with that. I am just asking questions to learn how to make the power, and why rpm's are not a commonly talked about part of the equation.
I will not be satisfied with simply going to 810 and excepting that as the final end all for a kz650 based engine.
I have always been a bit of a hard head, but please understand I am only saying the things I say because I do not fully understand the reasons involved. I do not mean to offend anyone; and I am not taking offense to your pokes at me... I come to this forum to learn about this bike and it's powerplant... not to piss folks off.
1977 kz650 c1
- PLUMMEN
11 Oct 2009 11:55
- MadMac74
11 Oct 2009 12:02
Well said :silly:
'78 KZ650 C2,810 conversion,stock kz 750 cams,with a Blueprinted Head both from a '81 KZ 750. BS 34 Mikunis, Mac /Kerker 4 into 1 with custom 2" comp baffle. 3 rd owner
'02 ZRX1200R, 3rd owner
'83 XR200R, 3 rd owner
'84 V65 Sabre 3 rd owner
