- Thank you received: 114
Installing a 900 crank into 1000
- racer54
17 Oct 2008 19:16 #242342
by racer54
Replied by racer54 on topic Installing a 900 crank into 1000
If I'm not mistaken, there are KZ1000 cranks with different size ends on them also. I believe the later KZ1000's are the ones with the larger ends but I would check first!
- timebomb33
- Thank you received: 10
17 Oct 2008 21:39 #242361
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Installing a 900 crank into 1000
the j cranks have a 25 mm diameter and the z1's and kz's up to 1980 have 22mm diameter on the rotor end if your crank is a stock 79 crank it will be a mk11 crank .
