Installing a 900 crank into 1000
- Exitpupil
79 KZ1000 LTD B3, 1075 kit, BS34 carbs, high velocity ported heads, K410 cams, V&H pipe w/custom baffle
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- mark1122
- Keep twisting it
- Thank you received: 109
The only advantage to a z1 crank is it will rev faster.
If u go z1 u just have to change the cam gears with it.
I have a z1 welded crank and slotted cam gears if u are interested.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Exitpupil
I have a spare Z1 crank with low miles and figured maybe it was a reasonable route to go to have it balanced and welded ready to drop in when I rebuild in a year or two? I was trying to accumulate the parts for a rebuild to minimize the down time, so I would not have to wait weeks while I sent parts out to the machine shop.
- 893cv
- Thank you received: 15
1980 kz1000 LTD
1978 Z1R
- mark1122
- Keep twisting it
The mk11 stator , rotor,and cover are dif.the output is 20amps. 50volts output A.C.
kz=?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Exitpupil
- mark1122
- Keep twisting it
By the way ,the electrics are interchangable(reg/rec.)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kawsakiman
- Thank you received: 6
the teeth are the same.
they rev better because a 900 crank is 14lbs lighter.
my advice is to send the cap out and have it milled and buy the support plate from ape.
oh yeah, don't forget to replace the cam chain. cheap insurance.
you will also have to change the ends on the stator. no big deal.
welding the crank is not really a must if your not drag racing.
but it sounds cool when you say you had it done.
we build 1200's and flog them with 900 cranks and have yet to twist one.
we did break a crank in a 1105 motor once but that one didn't have a support plate.
feel free to pm me for questions or pictures.
- mark1122
- Keep twisting it
you will need a stator and cover off a z1.
why would he have to change the stator and cover. I have been told by guys that have dont this. the kz stator will fit a z1 crank.
Have u found personaly that this is not the case?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- kawsakiman
they are different charging systems.
the magnet is on the crank and the stator is in the case.
- mark1122
- Keep twisting it
Have u ever tried? i only have a z1 and a mk11 ,and they have a dif taper on the cranks end so u cannot interchange them.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
