- Thank you received: 10
There's so much I don't know about this bike!
- timebomb33
I THINK MY POWERBAND BROKE
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- PLUMMEN
- Thank you received: 104
i just like things that fit me and my caveman way of doing things,that and i come from a long line of railroad blacksmiths and just like making stuff!:laugh:uh guys... I'm all for making my own tools... Example, HEX wrenches for the ZX636 front end axle bolt (requires two one for each side) and the prices of one wrench was rediculous $40-$60 each, so I made my own with a bolt and welded nuts on each side, $4 for all.
But this shim tool from Z1 is pretty much cheaper then you could even make...
thadley55:
Slow down a bit dude...
"P.S. I've had this thing since May I just really want to ride it!!!"...
Hell, I have been working on my project since last year, others have been working on theirs for over a couple of years...:blink: We all want to ride our babies sooner than later, ok, preferably before we die but be patient and do it right.
"that only 2valves were in spec!! I need shims"
2valves in spec.. Are you depicting the shim measurements using a feeler gauge. If so, what were your measurement?
How much of a difference where your measurements off spec?
"6 of the valves have no clearance"... None what so ever?
Go to Harbor Freight, Home Depot, Lowes, Ace hardware where ever and buy a digital micrometer that also does milli meter (mm) measurements, they're ~ $25. You can measure the shim in mm. From Z1, each shim is under $5 so but 4 each above and 4 each below or perferably buy a shim kit to cover all your needs.
OMR
- Old Man Rock
- Thank you received: 225
He seems to be having a hard enough time and as he has written in numerous postings... basically doesn't know what he's doing. I'm not trying to ping Thadley, only stating what he has written where he has jumped the gun/leaped with both feet/gone cowboy without truly analyzing WTF the problem is or what needs to be done.
Example, I need shims... Honestly, I'm not so sure he does from what he's written. Then again, WTF do I know.
Piece Brother...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
ThanksB)
P.S. I will try the spinning technique, I never even thought about that!
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- Old Man Rock
BTW... YOU DON'T PLACE SHIMS ON TOP OF SHIMS...
Good luck,
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
