There's so much I don't know about this bike!
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
It's me again, I checked valve clearances earlier on my KZ900 and found that only 2valves were in spec!! I need shims!!! Which ones do I buy, I mean what size. I am thinking about getting the tool that Z1 sells by motion pro to change shims without removing cams but I don't know which shims to order. How do I find out the difference? I mean I knoww that 6 of the valves have no clearance. If I check them all can I still ride it while I wait for shims to arrive? I don't even know if I'm making sense? I need help!!(obviously!)
ThanksB)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- KZQ
- Administrator
- Thank you received: 1415
Get the tool, remove the shims read or measure the thicknesses, order the shims you need.
While you're at it read WG's excellent article on setting valve clearances here:
Setting Valve Clearances
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- bountyhunter
- Thank you received: 337
Then you have to install thinner shims until you get clearance so you can calculate the correct size shim.Hello,:silly:
- APE Jay
- Banned
- Thank you received: 58
Jay
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- thadley55
P.S. I've had this thing since May I just really want to ride it!!!:woohoo:
- KZQ
- Administrator
Additionally, if the valves aren't seating you're loosing compression. Have you looked at the compression?
KZCSI
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
- BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
- coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- iroc355
- PLUMMEN
- Thank you received: 104
- Old Man Rock
- Thank you received: 225
But this shim tool from Z1 is pretty much cheaper then you could even make...
thadley55:
Slow down a bit dude...
"P.S. I've had this thing since May I just really want to ride it!!!"...
Hell, I have been working on my project since last year, others have been working on theirs for over a couple of years...:blink: We all want to ride our babies sooner than later, ok, preferably before we die but be patient and do it right.
"that only 2valves were in spec!! I need shims"
2valves in spec.. Are you depicting the shim measurements using a feeler gauge. If so, what were your measurement?
How much of a difference where your measurements off spec?
"6 of the valves have no clearance"... None what so ever?
Go to Harbor Freight, Home Depot, Lowes, Ace hardware where ever and buy a digital micrometer that also does milli meter (mm) measurements, they're ~ $25. You can measure the shim in mm. From Z1, each shim is under $5 so but 4 each above and 4 each below or perferably buy a shim kit to cover all your needs.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
