cam bearings?
  • PLUMMEN
  • PLUMMEN's Avatar
Re: cam bearings?
12 Oct 2008 08:49
#241425
thadley55 wrote:
Thanks PLUMMEN, I'll check there!!B)
i seem to be getting credit for everybody elses posts today,i try to help when i can but it was keith1 who gave location.:laugh:
Re: cam bearings?
12 Oct 2008 09:42 - 12 Oct 2008 09:55
#241430
thadley55 wrote:
Why tdc?B)
Supposed to be the crankshaft position where the camchain has maximum slack on the rear side, which allows the tensioner to have the most effect.
With point cover removed, align the advancer's T mark (for cyl 1/4) with the permanent timing mark on the case. This alignment will place the pistons in cyl 1/4 at TDC (top dead center).
A word of caution -- the camchain tensioner's lock nut and adjustment screw should not be tightened with Godzilla force, as these bolts have been known to snap. "Snug" is plenty good enough here.
The camchain tensioner adjustment may be made as frequently as desired.
Good Luck! :)
Last edit: 12 Oct 2008 09:55 by Patton.
