cam bearings?
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
11 Oct 2008 18:31 #241326
by thadley55
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
cam bearings? was created by thadley55
Don't know what I'm looking at? I took off the valve cover gasket and found that one of my cam bearings? or race?, i don't know what they're called,had spun out. They have, what looks like the proper tabs in place so I just removed the cap and put it back in place. What caused it to do that? Will it do it again? If so how much damage will it cause? I'm sure they don't cost as much as cams but, you know me, I won't spend it till I have to. Any help would be nice.
ThanksB)
ThanksB)
- PLUMMEN
- Thank you received: 104
11 Oct 2008 18:45 #241331
by PLUMMEN
Replied by PLUMMEN on topic cam bearings?
are you sure it was ever in there?:blink:
- racer54
- Thank you received: 114
11 Oct 2008 18:52 #241333
by racer54
Replied by racer54 on topic cam bearings?
I have never heard of that happening before. Was it in right before or have you been in there before and it was fine? They are cam bearings you were looking at. If they were locked in place with those tabs, they shouldn't have moved. That is very strange. Sounds like they weren't installed correctly in the first place. They should fit in there snug and actually feel them "click" into place. Did you feel that when you put it back in? If one of those happened to come out completely, the cam would wobble some in there and my guess would not be pretty. You can buy these things used for $10-$20 a set of 16 on E-Bay. Some will say to buy new...always...while I know lots of guys use them used. You just have to measure clearance to be sure they are the right thickness. They do vary somewhat but should generally be close.
- thadley55
11 Oct 2008 19:02 #241334
by thadley55
Replied by thadley55 on topic cam bearings?
Yea, IDK if they were in there right to begin with> I've been running it and haven't noticed any problems. It did click when I put it back. We shall see. Maybe I should start a new thread but I'll try it here. Where is the locknut for the cam chain tensioner? I can't find the location in my manual.
ThanksB)
ThanksB)
- PLUMMEN
11 Oct 2008 19:16 #241338
by PLUMMEN
do you mean the bolt and nut on side of stock tensioner?
- thadley55
11 Oct 2008 19:25 #241340
by thadley55
I guess the stock tensioner. Forgive my ignorance but I was told i could adjust the tension without removing the valve cover. I don't know where it is.
- keith1
- Thank you received: 2
11 Oct 2008 19:43 #241346
by keith1
Replied by keith1 on topic cam bearings?
should be on the back side of the jugs, between carb 2 and 3...
- thadley55
11 Oct 2008 19:49 #241348
by thadley55
Thanks PLUMMEN, I'll check there!!
- thadley55
11 Oct 2008 20:11 #241358
by thadley55
Ha! I found it!!:woohoo: Thanks again PLUMMEN . I didn't hear any thing move but I don't know whether it needed to. Anyway, that's all for now. Later this week I will be checking valve clearance, I havs to get different feller guages, mine don't go that small. I will let you guys know how it goes
ThanksB)
ThanksB)
- timebomb33
11 Oct 2008 20:25 #241359
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic cam bearings?
i've had that happen on one of my drag motors i put back in place and kept running it i never had any more problems with it it must have dislodged when i put the caps back on i checked every week after a race but i never had any more problems after that. if it didn't hurt anything i wouldn't worry two much about it just pull your valve cover off more often and check it out.as for the tension issue you don't pull valve cover to set tension get it to tdc on number 1 then set your tensioner simple as that.
- timebomb33
11 Oct 2008 20:32 #241360
by timebomb33
i've never used new cam bearings in my own motors i've built lots for my self gas drag motors ,hillclimbers, street motors,nitrous alcohol turbo motors even customer motors if the bearings arn't torn up i reuse them.
- thadley55
11 Oct 2008 20:36 #241362
by thadley55
Why tdc?
