Cam Idler Sprocket Question
- OnkelB
Re: Cam Idler Sprocket Question
29 Sep 2008 11:46
Even though the cam chain guide sprockets for the 900/1000s and the 650s have different part numbers they are the same part and can be interchanged, there are some differences to the rear guide bracket though - more info
here
and
here.
77 KZ 650 B1, 82 GPz 1100 B2.
- wiredgeorge
29 Sep 2008 12:17
The 79 and later idler assembly is not going to fit an earlier bike as it is shaped wrong and is larger. You have to use it with a 79 or later valve cover. The earlier idler assembly will work on the later bike with no problem. (this is with respect to the 903/1015cc family. Liska makes good stuff and Z1Enterprises.com carries most all their line. Not sure where APE gets their idler stuff but I would also buy from them with confidence.
