Cam Idler Sprocket Question
  • Gman
  • Gman's Avatar Topic Author
28 Sep 2008 04:08
#239019
Can someone tell me if it is normal for the outer part of the cam idler sprocket to slide side to side on the inner part of the sprocket? It slides smoothly with a light friction fit. There is no galling on any part. The sprocket looks practically new with no slop on the center shaft. My fear is the center part of the sprocket can shift to one side or the other and ride against the cylinder head. Is this normal or do I need to replace it? Thanks.
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Cam Idler Sprocket Question
28 Sep 2008 07:51
#239035
Hmmmm...don't THINK it's supposed to slide around like that.
What bike is this from?
(Put the model and year into your signature,ok)
Are there needle-bearings in the center section of that gear?
Take a pic of the front,and post it.
1977 KZ1000 A-1
  • Mark Wing
  • Mark Wing's Avatar
28 Sep 2008 09:40
#239061
Well I checked an old one I have and the center does slide out like you described.
Mark
Yorba Linda Cal.
  • Gman
28 Sep 2008 10:37 - 28 Sep 2008 10:42
#239071
Here's a few more. It's out of a '74 Z1 900.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
Last edit: 28 Sep 2008 10:42 by Gman. Reason: double
  • Gman
28 Sep 2008 10:39
#239072
Try again.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
  • drmadd95
  • drmadd95's Avatar
28 Sep 2008 10:46
#239073
When I had my top end off mine where like that too. I'm sure that's normal. Someone correct me if I'm wrong.
1979 KZ650
1979 KZ650 B (Main Ride)
1978 KZ650 D1 (sold)
1982 KZ750 (parts bike)
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
28 Sep 2008 10:53
#239075
That's how they are,on the 650's?:huh:
I wouldn't have thought that.
I suppose with oil in there,there wouldn't be friction though.
Different than mine,that's for sure.;)
1977 KZ1000 A-1
  • APE Jay
  • APE Jay's Avatar
28 Sep 2008 14:53
#239103
That absolutely does not look good. You should get the solid aftermarket one.
kzzone.com/sprockets.html
  • Gman
28 Sep 2008 16:34
#239110
Thanks Jay. I needed a definitive answer. Guess that's one more part to add to my list.
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
  • timebomb33
  • timebomb33's Avatar
28 Sep 2008 20:50
#239151
that idler is toast somebody suggseted the liska idlers excellent product i use them in my drag bikes and my street rides as well. funny thing about them there cheaper than stock replacment and a much better product
I THINK MY POWERBAND BROKE
  • Mark Wing
29 Sep 2008 08:33
#239203
Wow I guess it's good that it's an old one I checked, Ill toss it.
Mark
Yorba Linda Cal.
  • Old Man Rock
  • Old Man Rock's Avatar
29 Sep 2008 10:20
#239220
Ape Jay, the idler gear your showing is for the KZ900 & 1000 series... Liska, yeah baby...
Are they the same for the KZ650?
I don't think so due to OEM part number differences... And I don't see where the KZ650 models are shown on your web site...
Then again, WTF do I know....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
