- Thank you received: 114
Nitrous!!!
- racer54
30 Sep 2008 16:04 #239509
by racer54
Replied by racer54 on topic Nitrous!!!
Just be careful if you go to a longer arm. The longer the arm you use, the better rear tire you are going to need. 77KZ650 is right with what he says. If you go much longer then stock, get yourself a very god tire...it reallt makes a difference!
- jordan
- Thank you received: 5
30 Sep 2008 18:54 #239544
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic Nitrous!!!
thanks for those pics 77kz650. they are very interesting and thanks for your input. Thanks once again racer54 for helping me through this project
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- PLUMMEN
- Thank you received: 104
30 Sep 2008 19:03 - 30 Sep 2008 19:23 #239550
by PLUMMEN
Replied by PLUMMEN on topic Nitrous!!!
if you get too long of a swingarm you take too much weight off rear tire and it will go up in smoke.i try not to go more than 3" over and lower it as much as possible for a streetbike,some of those guys with 10-12" over on the arm dont even look like bikes in my book but as long as they are happy !;)Racer whats the length on you arm? looks like a good happy medium!oh what am i saying that bike is flat out beautifull!:laugh:
Last edit: 30 Sep 2008 19:23 by PLUMMEN.
- racer54
01 Oct 2008 16:25 #239694
by racer54
The swingarm is an 8" over arm. The tire on the bike in that picture is a 8" M/T slick with some grooves cut into it so it looks like a street tire going down the road. LOL Put a 180 Avon on there now but haven't had chance to test it!!! It that doesn't work out, then maybe a 17" wheel and a Shinko Ultra-soft. This long of a swing-arm needs a soft tire. Will probably switch arms to a swingarm with shocks so it's easier on this old behind. Fast, but rides like a tank with struts!
- PLUMMEN
01 Oct 2008 19:14 #239728
by PLUMMEN
ive run struts before on a streetbike,youre pretty much at the mercy of back tire for suspension!:S i prefer shocks anyway,makes it easier to transfer weight to rear tire unless of course youre running a bar than you are stuck with struts.did i mentio thats a beautiful bike?i put ol blue back up on my avatar as a motivator for my current project!
- racer54
01 Oct 2008 20:16 #239739
by racer54
Get out in the shop and get to workin' on that thing!!! We all want to see some pictures of your progress. You can get by somewhat with struts with a slick because the sidewalls flex some but a street tire sidewall is very unforgiving. Need shocks to let the rear squat and plant the tire. Oh...did I mention it's easier on an old behind...not to mention the back and everything else in that area?
- PLUMMEN
01 Oct 2008 21:30 #239750
by PLUMMEN
im already comitted to having it or one of my 55 chevys mocked up as a roller this winter!damn S.A.D.D(serious A.D.D):laugh: too many projects:S
- 77KZ650
- Thank you received: 7
02 Oct 2008 15:34 #239844
by 77KZ650
07 MDP Rookie of the Year
Replied by 77KZ650 on topic Nitrous!!!
yes you need a good tire if you stretch it out. i run a 190 shinko ultra soft @ 8 -10 psi. DOT approved. no problems hooking at the track (note the front end in the air) but it will light it up without even trying on the street. (i do have around 180 hp on just motor tho ) if you run bars, you must have a slick. no way around it if you have any power at all.
im 8.5 inches longer, but with my 6 inch longer tail section, it looks pretty good imo (it will look better when its painted the right colour tho!)
- racer54
02 Oct 2008 15:57 #239846
by racer54
Always wondered what air pressure is run in a Shinko. Lots of guys I see are running up around 20-25 psi in theirs. I always thought that would round out the tire too much and not have much for a footprint but it seems to work. I was told to run that pressure but thought it should be less. BUT...beings as I don't have one, they know more than I. Something to keep in mind. What does that arm put you at....about 66" wheelbase?
- timebomb33
02 Oct 2008 21:53 #239896
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Nitrous!!!
i had to rake both of my dragbikes for pipe clearance to keep the frontend from crushing the pipes .i am using stock trees forks and wheel.on my shoot out bike i used the frontend off of a 1991 1100 katana so it had alot tighter head angle and i'm using the gold label pro-stock pipe on it so it runs a lot bigger primary tube diameter so i definitly had to rake it besides i like the look. so really thats all that counts. also it makes the bike handle really good at high speed. so there
- PLUMMEN
03 Oct 2008 02:10 - 03 Oct 2008 02:16 #239903
by PLUMMEN
on a streetdriven bike running the rear a little lower than the front has same affect as raking front end a little and is easy to adjust depending on conditions.B)oh yeah id suggest running on the motor for a while and working the bugs out of the chassis and motor before you worry about putting the juice to that thing,you might be really shocked what a differance a big inch motor makes in a traction/handling challenged stock chassis .youre heading into a totally differant league !
Last edit: 03 Oct 2008 02:16 by PLUMMEN.
- 77KZ650
03 Oct 2008 15:43 #239989
by 77KZ650
i could run more psi on a better track, but my local one isnt the greatest. yes im around 65-66 inches. my tire flatten out a lot on the launch, uses most of the tread, but still doesnt flatten out completely. i probly get a 5.5 inch wide contact patch. the MCR hooks about the same if not just a bit better, and is a bit lighter but its a lot more money
