- Thank you received: 80
GPz550 #3 Rod Knock Probable Cause
- CoreyClough
- GPz550 Addiction
Well I finally gutted the engine that a little over 3.5 years ago. I had to stop riding the bike, due to a knocking sound heard at any rpm above idle. Got the bike with 38,000 on the odometer, and close to 6,000 miles later, and way more oil and filter changes than I should have(with motorcycle-specific oil, we won't get into that topic, no-no-no), it started one very warm summer day. Since then, I've put the bike in storage, and 2 years later, it still made the noise. Changed the engine with another, and haven't got into the noisy engine till now. #3 rod moves up and down on the rod journal, and the others don't. I removed the head, and cylinders, sent them to APE for rebuilding and opening up for their 615cc kit. Got everything back ready to install, and that was 2 years ago. I look at the parts and make "Veroom-Vroom" sounds. The plans are to do a complete rebuild of the bottom end before the 615cc kit and rebuilt head goes in. Taking no chances.
#3 Bearing Failure seems to be common from something to do with the oil clearances on these engines. It's what I've heard, and maybe someone can tell me if it's a "old wives tale" or reality.
Anyway, I've split the cases, and removed the rods from the crank. and I think I've discovered why #3 failed. See the pictures below, and fire away with the thoughts. Should be easy for some, and an awakening for others.
L - R is #1 - #4
You can see #3 Rod Bearing is obviously darker than the others, but looking closer . . .
#1 and #2 Rod bearings
#3 and #4 Rod Bearings
To my knowledge this engine has not been apart, and what you see is what came out of the engine from the factory.
Let me know what you think.
'85 GPz550(ZX550-A2)
- bountyhunter
- Thank you received: 337
I've posted this on www.gpz550.com as well.
There's the knock.
Any of the previous owners fond of doing wheelies?
Something starved the oil to that bearing.
- CoreyClough
- GPz550 Addiction
There, that might help.
- kpier998
- Thank you received: 1
- CoreyClough
- GPz550 Addiction
And "X" gets the square ! ! !There are no "ears" on #3 bearings.
This is exactly what I'm thinking. Why would there be "ears" on all the other rod bearings and crank bearings, and not have any on #3? I've looked on the back side to see if just maybe they were sheared off, but no sign of them.
Has anyone seen this before on maybe another size/year Kawasaki Engine?
- APE Jay
- Banned
- Thank you received: 58
Is that what yours look like Corey?
Jay
- CoreyClough
- GPz550 Addiction
I can barely pick out some type of tang there, but nothing like the other ones that have them still. Could be the case Jay. :S
Hey, the turkey is done!!! :woohoo:
These are pictures of #3 Rod Bearings only.
The Good, The bad, and The Ugly below:
So, any word on hearing about a cure for this tale of #3 land it's lack of oil or is it a farse. The rod journals on the crank all measure 1.296" (32.918 mm), and the main bearing surfaces on the crank measure 1.258" (31.953mm) so standard bearings should bbe used after a light emory cloth cleaning of the surfaces, right?
Anything that can be done to increase oil flow to these surfaces?
I can take pictures of the crank and rods too.
Hope someone learns from this, somewhere in the future.
- BSKZ650
- Thank you received: 14
Also the crank is going to be out of round needs to be replaced,
You have spent a lot of money, do a little more and make it right
77 ltd1000, current rider
76 kz900, just waiting
- CoreyClough
- GPz550 Addiction
Now this is a stock GPz550 Engine, unlike the other thread about the Big Bore 615 Engine.
- steell
Two questions:
Do I in fact, recall correctly?
If so, then why always #3?
- bountyhunter
There always has to be somebody at the end of the line...... that's probably the one who gets the wimpiest share of the pressure and feed.If so, then why always #3?
- PLUMMEN
- Thank you received: 104
