Replace Smog valve cover with Non-smog - concerns
- steell
23 Sep 2008 20:11 #238396
by steell
Replied by steell on topic Replace Smog valve cover with Non-smog - concer
He's in the UK,
Using a UK Spec cover,
And it's a 750 four.
I think he'll be all right.
- MekonFear
24 Sep 2008 02:41 #238423
by MekonFear
Replied by MekonFear on topic Replace Smog valve cover with Non-smog - concer
Kawsakiman - thanks for the diagrams and your help.
After checking mine last night the emission ports are obviously blocked by the valve cover. As Steell said, its a 750/4 1983 model - maybe the 'UK' covers are all made to block the ports by default - it's handy if so as when it was put on it wasn't something I considered.:blush:
I tried to take close-ups to post but as It was low-light the flash on my camera obliterated everything!
All seems good anyway, thanks for all the contributions
Ben
Ben
- wiredgeorge
24 Sep 2008 05:51 #238440
by wiredgeorge
Replied by wiredgeorge on topic Replace Smog valve cover with Non-smog - concer
Ben, After seeing the two valve covers that kawasakiman posted, it is clear that the cylinder heads are likely the same for all models but the valve covers vary to cover the exhaust runners where they are not required because of the use of an emissions system.
- roy-b-boy-b
- Thank you received: 103
25 Sep 2008 03:43 #238569
by roy-b-boy-b
Replied by roy-b-boy-b on topic Replace Smog valve cover with Non-smog - concer
Just fire the bike nup in the dark. If the holes are not covered you will have a nice blue flame. Roy
- wiredgeorge
25 Sep 2008 06:50 #238592
by wiredgeorge
It is easier to see the flames if you lift the tank up a couple inches while running. The flames will come up and clean off any grit and grime on the bottom of the tank as an added benefit! Great idea Roy!
- Zthou1977
26 Sep 2008 09:09 #238761
by Zthou1977
1977 Z1000A1, 1982-1986 KZ1000P (built from two piles of parts), Moto Martin Z1200 (trying to get it registered), 1977 Z650B1
Utrecht, The Netherlands
Replied by Zthou1977 on topic Replace Smog valve cover with Non-smog - concer
Ben,
Debben sells blanking-off plates for those valve covers. As it gives the same result as replacing the valve cover with a non-US cover, you will be perfectly alright. Besides, on my KZ1000 Police I had the same anti-smog installation, and just connected both of the with a length of hose. No problem.
Jeroen
Jeroen
- pburnhamb
- Thank you received: 2
28 Feb 2010 11:15 #350583
by pburnhamb
1978 kz650b (810, 750 head)
1976 kz900
1977 xs650
Replied by pburnhamb on topic Replace Smog valve cover with Non-smog - concer
If you just connect the two with a hose, wont the exhaust passing from side to side affect the valves? I have been running my bike like this but am wondering if it is doing dammage. the two covers on the top of the valve cover are filled with soot and carbon. I probably have to block off the 4 holes and not just connect the two (one on each side of valve cover) with a hose. When the exhaust vales let exhaust out, come of that exhaust tries to go to the other side through the hose. I know there are reed valves to only let air move one way, but some of the exhaust gas will get by over time because they werent meant to have pressuer pushing both ways.....right......?????
thanks
-patrick-
thanks
-patrick-
1976 kz900
1977 xs650
- pburnhamb
28 Feb 2010 19:34 #350649
by pburnhamb
1976 kz900
1977 xs650
Replied by pburnhamb on topic Replace Smog valve cover with Non-smog - concerns
Ben Please note: Although no board code and smiley buttons are shown, they are still usable.
Report to moderator
What i meant.....after im home from the PUB.,.......... the 4 holes (extra holes) from the head to the valve cover are flowing exhaust gas....that gas should flow out the exhaust, not over to the other exhaust valvesand out from there....
Report to moderator
1976 kz900
1977 xs650
- Tyler
- Thank you received: 92
28 Feb 2010 20:03 #350654
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic Replace Smog valve cover with Non-smog - concerns
I plugged the holes in my head and used a '78 valve cover. Just ran a tap in the holes for set screw but you could use pipe plugs. I would use a method like this to plug the passages.
